I will probably remove some, but I'm interested to hear how changing frequency response in different parts of circuit works. And hopefully have the ability to go from deep lows to a thin and high tone.rdjones wrote: I don't see anything that would keep it from working as discussed.
That's a lot of switches and caps, though.![]()
So it doesn't matter if I have the cap or not, just combine the resistance and it all leaks to groumd the same way, it doesn't affect the triodes work?rdjones wrote: You can use a single resistor for the "phantom PI" lower half, a single 220K.
I wonder why Fender has the 1 meg go to ground through the 56k resistor.
