Hum in Bandmaster
Fender Amp Discussion
Oddvar R
Re: Hum in Bandmaster
Post by Oddvar R »
martin manning wrote: Sat May 27, 2023 11:30 am Which Bandmaster circuit is it?
Ab763
angelodp
Post by angelodp »
Have you tried swapping the tubes, to see if one tube is the culprit. You say one tube causes the problem, on which tube socket? Or is it one tube with either socket?
I assume you have tightened all your jacks and pots and ground connections.
Oddvar R
Post by Oddvar R »
If I take out all the preamp tubes andt the tremolo tube, the hum is still there.
pdf64
Post by pdf64 »
Oddvar R wrote: Thu May 25, 2023 2:32 pm … The funny thing is that when I put in just one power tube, the hum goes away, with two it comes back.
I suggest to investigate the above some more. As it’s really weird.
Also, if you haven’t already, I suggest to add 1R cathode current sensing resistors to the output valve sockets. Or get a bias probe. As it’s kinda useful / essential to have an easy quick safe way of checking that.
So, with just the output valves fitted, the hum is still there (V4 might be regarded as part of the power amp circuit)?
And what current is each valve drawing, eg measure mV across each 1R resistor?
To fit cathode current sensing resistors, replace the wire link between each pin 8 socket lug and chassis common with a 1R (1 ohm 1/2W or 1W metal film).
pdf64
Post by pdf64 »
Delete
Oddvar R
Post by Oddvar R »
I wonder a bit about the call for pin 8 to ground, when I take away on of them, the hum lowers. Is that relevant?
Post by Stevem »
Not to be mean, but if you can’t see why pin 8 of a output tube needs to go to ground, even if thru a low value resistor then you really need to learn more about tubes.
What happens to the hum as you remove the tubes beginning at the input end of the string and ending with the PI tube?
Oddvar R
Post by Oddvar R »
martin manning wrote: Sun May 28, 2023 11:27 am What happens to the hum as you remove the tubes beginning at the input end of the string and ending with the PI tube?
The hum is constant.
So the source is the power tubes. They could be very unbalanced, there could be excess ripple on the bias voltage, or something is not right with the output transformer.
Last edited by martin manning on Sun May 28, 2023 12:11 pm, edited 1 time in total.
Oddvar R
Post by Oddvar R »
I have ordered a new OT, thanks Martin for being a great person.
Well, let's hope that is the correct fix. PDF is saying replace the two ground connections from pin 8's with 1Ω resistors from pin 8 to ground so you can measure voltage on pin 8 in mV, which will be numerically equal to mA flowing through each tube.
Oddvar R
Post by Oddvar R »
So where do I measure between?
angelodp
Post by angelodp »
OT's are expensive, 1 ohm resistors are pennies. Can you hold off on the OT until you check the current in those Power Tubes.
Oddvar R wrote: Sun May 28, 2023 2:40 pmSo where do I measure between?
Pin 8 and ground.
