In order to have an effects loop in a BFDR you must inject it just before the driver tube.
However the signal at that point can be as large as 20 volts.
Remember, adding an effects loop should be invisible to the normal operation of the amp.
That is to say if you plug the send into the return jack you should not notice any difference to tone, feel, or any other way of measuring performance of the circuit.
Fist thing you have to do is drop that 20 volts to a voltage that is normal for pedals...typically 1.5 VAC max.
Next you have to make sure the new lower voltage can drive a low z circuit...remember before it was driving a high z circuit.
Then on the return side, you must take the low loop voltage and boost it back up to the normal 20 volt area.
Because the devices in your loop are almost always use solid state devices to do their thing...you can not complain about using solid state devices to accomplish this feat.
So you must use a voltage divider, and have a single transistor to convert the impendence for the send, and on the return side you must have another one for a gain stage.
If done correctly this will net you an invisible effects loop on all black face circuits. ( you could also add a dual gang 1 meg linear pot to give you an all "Wet or Dry" setting or any blend that suits your taste.
