Fender Blackface Grounding
Fender Amp Discussion
Re: Fender Blackface Grounding
I use those same star washers on my bias test point jacks.
For the isolated Switchcraft jack I use one of those plastic step washers on the back side and a fiber washer on the nut side.
Bombacaototal
Post by Bombacaototal »
M Fowler wrote: Fri Sep 14, 2018 11:09 am I use those same star washers on my bias test point jacks.
For the isolated RCA jack I use one of those plastic step washers on the back side and a fiber washer on the nut side.
Many thanks Mark, I appreciate the help!
Bombacaototal wrote: Fri Sep 14, 2018 11:21 am
Sorry I edited my above post from RCA jack to Switchcraft jack. Mark
Bombacaototal
Great, thanks for the note.
By the way, are you securing your RCA jack at all? Or the way I did should be good enough...by the way I decided to ground it to the chassis in the end.
When using the isolation washer (stepped washer) it will not tighten well and I just leave it that way.
Have to drill the 3/8" hole larger to fit this stepped washer so why not just use a Cliff jack same size hole.
