5D6 Bassman amp build in 5E3 cab.
Fender Amp Discussion
loctal
Post by loctal »
I put a 5D6 amp into a 5E3 cab. The fender style input has a 12AY7 input and the other input has a 6SQ7 tube with Marshall type values from RobRob's website. Output tubes are 5881s and the negative bias is supplied from a 6X4 tube. Power supply is from 5Y3, 80 or both. A mercury 83 maybe used in the 80 socket or a GZ34 in the 5Y3 socket. The whole B+ goes through a 6-8 Henry choke before the plates. The amp sounds good but the effort to use a high Mu input tube for the Marshall input was not worth time rolling through 20 NOS 6SQ7 tubes to find two which were quiet enough to be usable.
loctal
Re: 5D6 Bassman amp build in 5E3 cab.
Post by loctal »
More pics.
Post by Stevem »
Nice looking build!
You might want to rewire that 6sq7 socket and audition a 6sl7 as they seem to have a better audio quality to them to me.
Allow me to rib you here with your post, I don’t think Jensen was around to make speakers in or about the year 1060, lol!
ChopSauce
Post by ChopSauce »
Very impressive! This is something your cat can be proud of... 8)
I like to wire brush the pine wood for finish, NB.
Post by Stevem »
By the way, is your Cat declawed? It could be eying your nice new grill cloth when your not looking!
loctal
Post by loctal »
The cat has his claws. The grill cloth is from an old Hammond tone cab. Everything in this build was vintage and used. At first, I built the amp with used paper and wax capacitors that were tested good but were too leaky so in went new caps. I won't rewire the Fender input for 6SL7 tubes but I will make a tube socket adaptor for that channel.
