Thanx Guys,
Those kinds of comments, especially from youse guys, serve to swell my head a bit more!
The next victims of my soldering iron debauchery will be to accomplish two things. The same tonal response with just a tad more drive/gain, enter the Tweed Super into the cathode biased Tweed Deluxe power section and to make a lower wattage/volume, but with identical sounds of this Tweed Deluxe or the Supluxe, if that works out.
I've never had any experience or success with single ended construction and from some friends' attempts, it appears less simple than it would seem. This Deluxe
CAN get a tad too loud if I'm not careful with my playing technique and "God forbid" using an attenuator.
I guess my power section planning is torn between several avenues:
A) Going single ended, but worried that losing the character imparted by push/pull operation may be a tough battle.
B) Trying a dual triode like a 12BH7 (or similar) in push/pull configuration, but having played through several amps using this method has not totally sold me on this. I'm not sure if it was the power section that didn't quite float my boat on them or if it was simply poor overall amplifier design!
C) Find a lower power/dissipation tube (not sure if any actually exist) to use for a push/pull design?
Thanks Again Guys,
Gene
