OCD Fulltone
sergio
OCD Fulltone
Post by sergio »
Hi , I'm searcing the schematic of OCD OVERDRIVE Fulltone , anyone can help me?
Re: OCD Fulltone
The OCD is reportedly based on the Voo Doo Labs OD but uses FET's for the clipping.
http://www.freeinfosociety.com/electron ... hp?id=1208
http://www.freeinfosociety.com/electron ... .php?cat=1
sergio
Re: OCD Fulltone
Post by sergio »
Thanks for the informations , I'll seek in web again .
Sergio
Re: OCD Fulltone
When I googled for it, it seems you are not alone in looking for a schematic.
All my searches were guys asking, "Do you have the schematic for the OCD?"
moj067
Re: OCD Fulltone
Post by moj067 »
Check :
www.freestompboxes.org
Salud!
Deric
Re: OCD Fulltone
Post by Deric »
Not a schematic, but a start........
http://www.aronnelson.com/gallery/main. ... emId=14049
Deric®
mhuss
Re: OCD Fulltone
Post by mhuss »
I have an OCD, and it is fairly well gooped. I can say for sure there are some TO-92 transistors and one DIP-8 underneath.
--mark
sergio
Re: OCD Fulltone
Post by sergio »
OK Mhuss , but there are thousand OT-92 and operational amp.
You can tell me the exact initials?
Deric
Re: OCD Fulltone
Post by Deric »
The newer versions of the OCD are not gooped. There are 3 TO-92 type parts. 2 of them are 2N7000 used as diode clippers and one is for his silent switching/LED.
The op-amp is a TL082.
I believe there are now 4 different versions of the OCD. There are gut shots and clear directions on how to change between v1, v2 and v3 on Fulltone's web-site.
http://www.fulltone.com/PDfFiles/OCD%20 ... _small.pdf
Deric®
sergio
Re: OCD Fulltone
Post by sergio »
Thanks Deric but I'm not able to enter the link
I don't know :cry:
doctord02
Re: OCD Fulltone
Post by doctord02 »
the link is a .pdf file, so you must have Acrobat installed. It opened fine for me.
sergio
Re: OCD Fulltone
Post by sergio »
I don't know , I've Acrobat Reader , but when clik on link , the screen become white...boh ... :cry:
skyyamps
Re: OCD Fulltone
Post by skyyamps »
if anyone does figure out a schematic, draw it out or something. people would kill to have it.
-skyy amps
pamaz67
Re: OCD Fulltone
Post by pamaz67 »
Check freestompboxes.org.
Gut shots and hand drawn schematic with an error, but AFAIK quite easy to correct.
I haven'seen it in detail BTW.
Finally a small hijack on the post. Pls. check my website www.paolomazza.com ( online since at least yesterday!!!!!!) and let me know what you think on the guestbook.
Ciao from Italy.
Paolo
Bernardduur
Re: OCD Fulltone
Post by Bernardduur »
Check Freestompboxes.org
The OCD is "just" a VoodooLabs Overdrive, slightly modded. Mods are a tubescreamer like gain control, some value changes and a versatile tone section. Clipping is done with MOSFET's protection diodes to Vref (4.5V).
There are now 4 versions; the last one (v1.4) has an additional germanium diode next to the MOSFET protection diode on one side to make the clipping assymmetrical
Great pedal!
Alles is makkelijk behalve de moeilijke dingen
I love pedals; Technophobia; Analog Audio Solutions
