MX-35 or MX-10 Parts Search
dorrisant
Post by dorrisant »
I have one of these here. I would love to rebuild it and use it, they are very nice stock. I have modded them a lot in the past and they can be even better that way. My problem is, one of the channel allocation switches is missing. A business partner and I pulled it to replace one for a customer some years ago. This one has sat here as a potential parts donor since then. That is all that is missing, the lever style channel selector switch. I still have the "knob" that goes with the missing switch, bit no switch.
Just wondering if anyone here would happen to have one or even know where to search... Maybe a particular forum that I could post this same request in. These MXs are Grammy award winning quality. I'd certainly like to get use out of it.
I posted similar in groupdiy as well.
Upon further review, the switch is the Line-Off-Mic switch for channel 4.
stelligan
Re: MX-35 or MX-10 Parts Search
Post by stelligan »
Might see if these folks can lead you in the right direction:
https://www.electricandcompany.com/
dorrisant
Post by dorrisant »
Thanks for that link. I reached out to them.
Post by Stevem »
Those look like what' could be replaced with what's called a Mega switch for guitar pickup selection.
They are made to be configured in many ways
They can be had at StewMac.com.
Also since it's only switching gain levels between Mic and line if you did not mind drilling a hole in that slot grove you could just use a mini toggle switch.
dorrisant
Post by dorrisant »
I certainly don't want to deface this thing at all. So no mini switch.
Post by Stevem »
The bolt Ct to Ct on these types of switched is 1.600".
