Wild new effect
Wild new effect
Me: Just one more...
Re: Wild new effect
I have to say, that thing is AWESOME! I normally don't feel like that about a roadblock between my fiddle and amp, but that thing is really cool!
vibratoking
Re: Wild new effect
While that box has some interesting sounds, I think you'll quickly find that playing convincing organ on a guitar is far less than optimal. I have been down a similar road with a guitar synth and other devices. The big issue for me is being able to sustain common tones while changing chords. Like a real organist would do. The organ sound of the EH box is infatuating for a moment, but my experience says it wears off fast and then you are left with a 'bad' organ.
Re: Wild new effect
(deleted)
Re: Wild new effect
I bought one on the strength of the advert posted above. I tried and tried to like it. I even used it at a band rehearsal. In the final analysis, I doubt I'll ever use it. MIDI guitar with a good B3 patch feels and sounds better (I use a Roland GK rig). The B9 is very unnatural "feeling" from a guitar context. Why spend decades developing nuance and feel, only to have it vanish inside a pedal?
Not my cup of tea.
Not my cup of tea.
Re: Wild new effect
Well...that was fun...
Re: Wild new effect
I use a Roland GR 33 but still would like to try the new EH pedal. Key to keyboard on guitar is hold the chords and notes let them ring out then slowly releasing them otherwise you sound like a guitar player.
vibratoking
Re: Wild new effect
I use a Roland GR 33 but still would like to try the new EH pedal. Key to keyboard on guitar is hold the chords and notes let them ring out then slowly releasing them otherwise you sound like a guitar player. Smile
Mark, you're right and it does help. But it is physically impossible to play like the real thing. In my book, it just doesn't work. You can do a quick an approximation, but the physical limitations just can't be overcome.
Re: Wild new effect
Oh I agree doesn't sound nearly as good but makes a 4 piece band sound fuller in these Minnesota and North Dakota bars.vibratoking wrote:I use a Roland GR 33 but still would like to try the new EH pedal. Key to keyboard on guitar is hold the chords and notes let them ring out then slowly releasing them otherwise you sound like a guitar player. Smile
vibratoking
Re: Wild new effect
The full sound is a good thing. That's my goal as well. I use a synth which allows me to have both guitar and 'organ' at once, or I use a CLS-222 running through a second amp to get some swirly thickness. I actually like that better cause it's more organic.
I guess that's enough of a derail.
- Reeltarded
Re: Wild new effect
Playing for trigger dynamics is a sport.
Throw a piano sound up and let's see how good your technique is.
Re: Wild new effect
The B9 sounds even better with a Leslie or Leslie pedal after it. I tried a lex with it and did not stop playing for an hour. The tracking is great too. For the best results you do need to think like an organ player, don't bend notes, etc. I did not care for the click adjustment though. It did not like a dirt pedal in front much. Maybe after, but did not try. The Classic rock sounds like deep purple anyway, no dirt pedal needed.
My friend is running it into a bass cab and guitar cab, split high and low through my rotosphere, he says it is incredible, and he's playing bass through it.
vibratoking
Re: Wild new effect
Got that right. No one's technique is good enough for that.
