Garage heater
Garage heater
Qmark MUH102 Electric Shop / Garage Unit Heater
Anyone wired up one of these units? 220v using simple 2 wire thermostat.
Instructions are crazy regarding AC hookup L1 L2 and ground lug found those way inside the bottom (cover swings open). Control block for thermostat has all kinds of connections and instructions suck. I'm thinking Red and W1.
Re: Garage heater
I would call them up and see what they have to say. Beware, 50/50 you know more than whoever they let you speak with. After that you may have to (oh no) call an electrician!
You might want to find an electrician form and pose the question there. It's too bad about what happened at alt.guitar.amps where a few bad apples polluted the place. There were a couple of licensed master electricians there who probably could have done this in their sleep.
Re: Garage heater
Thanks Phil, I think I'll talk to a local electrician and get it installed correctly.
allclear7
Re: Garage heater
Post by allclear7 »
What ya got there is a two stage heater. First stage is w1/second stage is w2
Power gose out on red and returns on w1, then if w1 dose not satisfiy the demand for heat then the second stage will be brought in when there is a 3 degree diffrence form your set point. I do a lot of these in smalll warehouses. The thermostat you can use would be for a heatpump or electric heat.
there are no problems , only solutions J.Lennon
Re: Garage heater
Thanks for the information. I have a two wire thermostat currently that the supplier said is used with this type of heater.
Ran 8-3 nm wire 50A breaker. I could have used 8-2 nm after looking this thing over but I went with the supplier's suggestion since they sell a crap load of these units. The heater has L1 and L2 connections and ground lug connection but no neutral block. Apparently there is no need for 110v for the fan since the neutral isn't being used correct?
guitarsnguns04
Re: Garage heater
Post by guitarsnguns04 »
Yeah mark that's correct . The fan motor is 220 as well so no neutral is needed.
Edit...I just re- read your post...also note #8 wire should be on a 40@ breaker not a 50
Re: Garage heater
Thanks will get 40 amp breaker.
John_P_WI
Re: Garage heater
Post by John_P_WI »
Hey Mark, Hope you had success with the heater install... here comes winter! Seems early this year.
Re: Garage heater
Now that Thanksgiving is over I can get back to my many jobs and the snow is here.
surfsup
Re: Garage heater
Post by surfsup »
Mark, I have not. I'm putting radiant heat into my garage slab instead... 8)
Re: Garage heater
I have a hanging natural gas heater in my garage but this heater is going into my oldest son's garage.
In 1999 I built a new 30 x 40 shop and put floor heat in, built a boiler, expansion tank, and circulating pump system with three zones I could control. Plus hanging propane heater for when the garage door opened up robbing heat and for quick recovery. Plus wood burner. I was wore out after building that shop, never again.
Nice to have heat in North Dakota winters. :)
surfsup
Re: Garage heater
Post by surfsup »
radiant done right won't cool down with garage door open...but yea it is a pain. this is new construction though so it's easy...gotta do it!
Re: Garage heater
Its 70 here now supposed to get ice storm tomorrow
That uasualy means no power for a while
beasleybodyshop
Re: Garage heater
Post by beasleybodyshop »
This is how my old man starts his heater :D
Re: Garage heater
Yup done that too! :lol:
