Hi wattage rheostats
EtherealWidow
Where would you guys recommend buying rheostats? Specifically 25 ohm, 100W (minimum). Cheapest I've foud is $45 a pop.
- LeftyStrat
Re: Hi wattage rheostats
What would you use that for?
If you can manage with 35 Ohm, here at $12.
http://www.surplussales.com/Potentiomet ... ost-2.html
- LeftyStrat
At that wattage, I assume he's building an l-pad.xtian wrote:What would you use that for?
EtherealWidow
What am I doing with them? Well, the aforementioned dummy loads in a different thread won't work. Built them for the church with a line out, but they don't have the capability of using impulse responses, so I figure some cheap attenuators are in order.
Sorry, I still can't figure out why you are using attenuators in a church. You also mentioned that it would be used for line out. I am not trying to be nosey but just like to learn what "church with a line out" really means.
If you can use I have 2 pieces of a Ohmite 0534 50 Ohm 150W
I can sell you for $12.50 each
