Moderators: pompeiisneaks , Colossal
Posts: 10189 Joined: Sat Feb 14, 2009 4:38 am
Post
by Reeltarded » Fri May 18, 2012 3:19 pm
Ok, I am a idot.
I just rebuilt one of my Marshalls from the inputs to the tone stack.
Don't use a 1.5M grid resistor. Use a 68k. They may appear similar, but trust me.. because I know all about that.
lmao
Posts: 7263 Joined: Mon Apr 19, 2010 8:15 pm
Post
by xtian » Fri May 18, 2012 3:32 pm
Hello, 'tarded!
My name is xtian, and I am an idiot. If you search my posts you will find several hi-larious, idiotic incidents.
Most recently I caught a little 120vac thru the ring of a fuse holder while I was trying to insert a fuse into a live circuit. Not a big shock, but certainly a nice reminder.
You are among friends. Idiot friends.
Post
by Reeltarded » Fri May 18, 2012 3:41 pm
teehee.. It's not my only mistake, but it was a funny one.
If anyone wants any pointers on cleaning up a Marshall or similar amp, try a huge input grid resistor! Sounds INSANELY clean. Clean enough to drive me insane lol
Posts: 4401 Joined: Sat Jul 23, 2011 6:17 pm
Post
by cbass » Fri May 18, 2012 3:41 pm
Shoot you didn't even cause a fire or fry an expensive tube or electrocute yourself.
You're aren't idiot till you do all these things at the sametime
Posts: 14036 Joined: Wed Jan 16, 2008 2:19 am
Post
by M Fowler » Fri May 18, 2012 6:20 pm
About a half hour ago a new 33uf cap blew and what a sound that is, kind of like an old steam engine releasing pressure.
Post
by cbass » Fri May 18, 2012 6:27 pm
One time I put in a cap in the bias section in backwards.Even though when i put it in I thought ok positive end goes to ground.
Made a nice little show
Post
by Reeltarded » Fri May 18, 2012 6:51 pm
I don't want a cap to blow up on me.
You guys are scaring me.
Colossal
Posts: 5205 Joined: Sat Oct 20, 2007 9:04 pm
Post
by Colossal » Fri May 18, 2012 6:57 pm
Safety glasses are always a good idea when peering into a chassis, energized or not.
Smiley here is wearing his safety glasses
Wide Eye isn't and what he doesn't know is that we're pumping 800V into his 450V rated power supply caps (which are actually fake Chinese cap-within-caps because he also cheaped out on parts as well as disregarded safety)
Post
by Reeltarded » Fri May 18, 2012 8:07 pm
I just turned my variac to 140.
Posts: 15446 Joined: Wed Oct 17, 2007 1:01 am
Post
by Structo » Sat May 19, 2012 1:51 pm
You'll shoot your eye out!
<<<<I usually use a butter knife in the socket but sometimes I use a fork.
NickC
Posts: 1814 Joined: Fri May 14, 2010 1:05 pm
Post
by NickC » Sat May 19, 2012 2:16 pm
Structo wrote: You'll shoot your eye out!
[img:80:80]
https://tubeamparchive.com/images/avata ... 92725b.jpg [/img]
What I like about using a fork is, you can bend the middle prongs out of the way and hit
both sides of the socket. Works like a charm.
Post
by Reeltarded » Sat May 19, 2012 2:40 pm
I already destroyed two sporks trying to bend the middle "prongs" back. Should I use heat? This plastic is brittle.
Oh well. back to kfc.
NickC
Post
by NickC » Sat May 19, 2012 4:02 pm
Reeltarded wrote: I already destroyed two sporks trying to bend the middle "prongs" back. Should I use heat? This plastic is brittle.
Zircon encrusted tweezers also work quite well; no pesky prongs to deal with.
Post
by Reeltarded » Sat May 19, 2012 7:26 pm
Is this one of those Stew-Mac tools looking for a purpose?
Previously I just checked wall voltage by putting my tongue on the B+ and then dividing by the number of winds. Is that wrong?
Post
by cbass » Sat May 19, 2012 10:57 pm
NickC wrote: Reeltarded wrote: I already destroyed two sporks trying to bend the middle "prongs" back. Should I use heat? This plastic is brittle.
Don't misuse a rare and valuable implement.
Those are only for harvesting dental floss. geez everyone knows that.
Well i guess they have another use.If you sterelize them with a lighter first.
