Garage sale
ampmike
Cool
Post by ampmike »
Thanks guys,Ill check it out,Thanks Mikey
ER
Re: Garage sale
Post by ER »
6aq5 is a 7-pin 6v6 equivalent, with the small bottle it ends up sounding like a cross between 6v6 and el84, nice compression and chime.
-ER
Chappy
Re: Yea
Post by Chappy »
ampmike wrote:Yea,Kinda stinks,They look real cool!Tom,Mark was saying I might be able to put the Power Tranny in something.It would be nice to be able to use it in a rocket or 18 watt. RCA 105771 Pim:117 v. 60 cy. Plate 292-0-292 V. 72 Ma Fil #1= 5 v. 2 amp Fil #2 = 6.35 2.75 amp What do you think? Mikey
Sounds like you have a great transformer for a tweed deluxe or princeton build. I just finished a 5E3 and I was looking for a transformer with those specs.
Chappy
ampmike
Tranny
Post by ampmike »
Thanks Chappy,Im going to do a princeton soon,Thanx for the info,Mikey
David Root
Re: Garage sale
Post by David Root »
+1 on the 6AQ5, I built a Harvard with all 7-pin tubes several years ago, just loaned it to the neighbor's 16-year old. Great tone with a Weber Jensen style speaker.
rp
Re: Garage sale
Post by rp »
The 6CG7 / 6FQ7 is wanted by the Conrad Johnson crowd, might sell well on eBay.
I'd immediately start work on a 4 6AQ5 amp.
If those were all a mix of 12AX7s, 5751, 6027, 12AY7, 6201, 6DJ8 7199 EF86 - you'd have had a heart attack. So, in that way you are lucky.
renshen1957
Re: Garage sale
Post by renshen1957 »
surfsup wrote:I see some 6aq5s in there, are those similar to the 7-pin small tubes 6AL5s?
I built a distortion pedal from Merlin's Sparkgap design using the small 7pin tubes. pretty cool pedal.
https://tubeamparchive.com/viewtopic.php?t=14365
Hi,
The 6AQ5 is a miniature 7-pin (B7G) output beam tetrode. Ratings are virtually identical to the 6V6 at 250V and was commonly used as an output audio amplifier in tube TVs and radios.
Garnet Amps used the tube in for their Mohawk Custom (parallel tubes SE).
Also known under Mullard-Philips tube designation EL90. There are also versions of this tube with extended ratings for industrial application which are designated as 6AQ5A and 6005W.
Best Regards,
Steve
ampmike
RCA
Post by ampmike »
Hey Guys,Strange thing,That RCA tranny was at the Garage sale new in the box,It looked like it was enclosed in a sguare metal box.I went to remove it hoping to see a normal tranny and its like its had clay forming all around inside.All you see is the wires coming out of clay.Anyone ever seen this?Ill get a picture,Mikey
David Root
Re: Garage sale
It's just potted, that's all.
Travst
Re: Garage sale
Post by Travst »
I had a 2/8w Reason Bambino combo with a 6aq5 in it. Great amp, it sound luscious with that tube.
I need more practice, not more gear.
