Alrighty....the build is beginning.... I have the chassis, the trannies and choke mounted, the tube sockets all mounted too, and the faceplate just arrived. However, when I try to mount the jacks and pots, I find that the shaft of the pots and jacks isn't quite long enough to allow for a lock washer on the inside of the chassis. The chassis is .080" aluminum, and the faceplate is about .0625" thick. I can get the nut on, but no washer or lock washer. I didn't even think of this when I ordered the faceplate, but I'd really like to put a lock washer inside the chassis to keep the pots from loosening up after use, etc...it just seems like a nice, solid build idea.
Any ideas? I know that some of the pots (Alpha, specifically) have a little peg that you can set into a hole on the side of the pot hole in order to keep the pot from rotating out and loosening up, but I'd like to use CTS pots or other "nice" pots, and they don't have this option. The goal is to use high-quality parts and to secure them well...
Many thanks.
