Installing a line out on a 5F1 Tweed Champ
Tubetwang
Post by Tubetwang »
Any of you'se guys know how to put in a line out on a 5F1 Tweed Champ.
I've used this Ceriatone layout...
www.ceriatone.com/images/layoutPic/fend ... out200.jpg
Thinking of using this line out to overdrive the Express... :roll:
I thought maybe a .01mfd cap on the 12AX7's pin 1?
collinsamps
Ths will do it
Post by collinsamps »
a .01mfd cap on the 12AX7's pin 1 would give you way to hot an AC signal.. Taking it from the secondary of the OT gives you a signal that has already been "transformed" to low voltage high current ac signal.
This is a very basic solution. The pot = volume / amplitude, the 47K can be adjusted to give more or less signal. For a champ 27k or so might be a better fit. you can add a tone pot easily as well.
Tubetwang
Re: Installing a line out on a 5F1 Tweed Champ
Post by Tubetwang »
Hey thanks Craig! 8)
Nothing like knowing you stuff.
I went through your web pages.
Nice amps!!!
Here is my spitfire schematic with a line out.
Tubetwang
Post by Tubetwang »
Great!
Thanks Mark!!
No problem Tubetwang hope that was what you wanted.
