Basically it is a Brown Deluxe preamp paired with a Komet Constellation 6SN7 channel run in parallel into a Brown Deluxe PI which runs into a 5E3-ish cathode biased 6V6 power section. 5AR4 rectified. AC heaters (for now...).
I fired it up and nothing exploded. Good. The PT is hummy...but it is a Mercury Magnetics clone of a Brown Deluxe PT, so I guess they cloned the hum as well. B+ voltages read out properly on all the tubes and throughout the line. Heater voltages read out at correctly as well. All grounds look to be solid. No solder joint issues that I've noticed.
Essentially, I turn it on and hear a fairly pronounced (though not terribly loud) AC hum (low, deep, powerful...not buzzy or fizzy hash from gain issues), and when I play through it no sound comes out. At first I figured something was wrong with how I coupled the two channels, but then I suspect maybe an input jack issue?
Again, this is just my 2nd build, so I'm sure I (obviously) screwed something up...but I'm so close I can taste it....but I just can't hear it.
Attached are copies of the schematic and a few pics of the build. Lemme know if you see anything suspect. I'm off to get a new soldering iron tip tomorrow (figures it would break after literally the LAST solder joint) so I can get to troubleshooting....
MANY THANKS!
