"Sub Zero" Low Voltage Submini Push/Pull Amplifier
frequencycentral
Last edited by frequencycentral on Sun Apr 11, 2010 3:22 pm, edited 1 time in total.
Re: "Sub Zero" Low Voltage Submini Push/Pull Amplifier
Another cool design!
The obvious solution to the voltage quandry is the reverse filament trans fed by AC at the heater voltage.
A bit low tech but effective.
Or, for DC, how about a PWM DC-DC converter into a voltage tripler or quadrupler?
frequencycentral
Last edited by frequencycentral on Mon Apr 12, 2010 5:54 pm, edited 1 time in total.
Since you are not running high volts, a HV mosfet is semi overkill. Motorola used to make nice 2 terminal CCS...not sure how much voltage would get thrown away across the device. Mosfet is cheaper, though, and those Motorola parts are obsolete.
Dirt common DC-DC converters go up to 28V, which would give ya twice as much wiggle room.
Or textbook RC voltage multiplier across any of these newfangled approaches would hook you up.
But you are talking to the wrong guy. I'm so old school I want octals in my projects!
- VacuumVoodoo
The PI will be biased into cut-off. I would recommend to use boot strap bias scheme here.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
frequencycentral
Last edited by frequencycentral on Mon Apr 12, 2010 5:55 pm, edited 1 time in total.
- VacuumVoodoo
http://www.freewebs.com/valvewizard/cathodyne.htmlfrequencycentral wrote:Thanks - but can you expand on that idea a little please, maybe by modifying and re-posting my schematic?VacuumVoodoo wrote:The PI will be biased into cut-off. I would recommend to use boot strap bias scheme here.
Thanks again,
Rick
Aleksander Niemand
Zagray!-review
Zagray!-review
frequencycentral
