Some of you may recall when I posted about this pedal when Jay offered it to Gear Pagers for a reduced Christmas price of $150.
It took him a little longer than estimated to get them built but I told him I didn't care because I wanted a good one and not to rush it out.
He did not disappoint.
This is made by Jayson at http://gaspedals.net/
He did a very nice job on this pedal. The graphic is done very well and is oversprayed with some kind of sparkly stuff.
This is a silicon fuzz pedal.
The DC jack is standard 2.1mm 9V center negative. The toggle switch is
vintage to the left and modern to the right. Tone will change a bit
when volume goes up.
So it kind of changes the feel of the tone when you flip the switch one way or the other.
The build quality is among the best I have seen inside. A very pro wiring job and a high quality pcb. He does goop his components with epoxy to deter cloners but that is fine as he has a right to keep his design to himself.
Jay and Gaspedals is best known for his Carburetor or Carb pedal which is best described as a booster or overdrive and can be used for both.
The Bettie really does sound good and has that bite and spitty nature that a silicon fuzz is known for. I also have a Analogman Sunface w/Sundial that is a Germanium fuzz. While that pedal is awesome as well it really doesn't seem to be bright enough to cut through the mix.
But, the nice thing about a Germanium fuzz pedal is, that it cleans up when you back down the guitar volume and you can almost get a clean tone if your amp is not cranked up to where you are into distortion.
With the silicon fuzz, you don't really get the clean up with the guitar volume control but that's ok, that's what the true bypass footswitch is for.
The Bettie Fuzz has a real lively tone that sounds good with either single notes or power chords. Also sounds great with single coil pickups as well as humbuckers.
For $150 I am glad I bought it and it will have a place on my pedal board.
I give it two thumbs up.[img:26:28]http://i23.photobucket.com/albums/b392/ ... s/Dude.gif[/img]
[img:577:498]http://i23.photobucket.com/albums/b392/ ... ettie1.jpg[/img]
[img:577:498]http://i23.photobucket.com/albums/b392/ ... ettie2.jpg[/img]
[IMG:577:498]http://i23.photobucket.com/albums/b392/ ... ieguts.jpg[/img]
