anyone know of a sutable replacement spkr for a SVT 8x10 cab?
2 spks are blown. rest are ok.
original spkrs are 32 ohm.
jensen makes a 32 ohm 10" rated @ 50 watts.
trying to see if emenence makes a special order .
any ideas????? jeff.
AMPEG SVT
Re: AMPEG SVT
can the customer afford the emi's or will he go with the Jensens?
SVT
i did not see the emi's @ 32 ohm. but they would be close to $100. BUT
@ 100 watts. the jensens are 50 watts, and at $35. so i think ill put him in those.
not sure how to test the spks individualy other than for resisrance. the 2 i know are blown is just from pushing the cones and hearing and feeling the unwound voice coil rubbing.
ill load it all up then hit it with my 100 watt home grown showman then listen to each one individually.
cleared to land
Re: AMPEG SVT
http://www.fliptops.net/
if you don't see what you need just email they are very helpful with everything ampeg
My Daughter Build Stone Henge
