Epi valve standard
Granite777
Epi valve standard
It has a noise a rattle in it and it seems to get a darker tone the longer I play it. I changed the tubes to RCA's and it helped some. But I played it again last night and got that rattle noise again. I even went in and grounded all the pots to see if that would help. I just wanted to know if any body had any ideas to help me kill this problem. I see in the valve jr they cut a jp1 jumper. I wonder if that can be done in this amp. I can use any advice out there. Thanks Granite777
Re: Epi valve standard
Your talking about a stock Valve Junior Epiphone the combo model or head? What speaker are you using that you get this dark sound and rattle? Turret Boards.com has alot of info on this amp if you like.
Mark, the Valve Standard is the big brother to the Junior, I believe it's 15 watts with DSP. To the OP - I'm not sure what it is that rattles, but I have heard quite a few complaints to that effect. Not having actually heard the rattle myself it's hard to say where it's coming from but if the cabinet is made from crappy plywood (probably a safe assumption) the rattle could be a small piece rattling around in a void in the wood. If it's something else though you can probably track it down by having someone else play while you check out the amp.
"I never practice my guitar. From time to time I just open the case and throw in a piece of raw meat." --Wes Montgomery
Maybe try plugging the Standard's output into another cabinet and see what happens. Then try another to drive the cabinet of the Standard with another amp. It might help you figure out where the problem is coming from.
Granite777
Its a pain Last night it was the same thing again its almost like the speaker is distorting buts its not the speaker. I put in a eminace out of a fender . I think its in the board myself. These boards are a work of art. I bought an old stromberg carlson amp 1951-au 42 THIS WEEKEND.. now thats a work of art. point to point, simple. I will have to post the photofact folder on this one. 6sf5 mic 6j5 af amp 6sc7 driver-phase inverter 2 (6L6G) PO 5Y3GT RECTIER. I thank you all for your imput and I will let you know what I fine Thanks again Granite777.
