I would like to back off a 2x10 speaker cabinet just a bit 3-4 db when it's running in parallel with a 1x12 cabinet.  I don't really need adjustable attentuation.  Maybe a DPDT switch and a LPad (Driver Attenuation Circuit).  This appears to be one resistor between the speaker (R2) and one on one of the leads (R1).  I found a place that has a calculator where you put in the Ohms and required db attenuation and it gives you teh values of the resistors.  For example:
Z = 8 Ohms
A = 3 db
Parts List = Resistors
R1 = 2.34 Ohms
R2 = 19.39 Ohms
My questions:
- Does this work well?
- What kind of resistors would you use for 35 watt amp.  (When it's being used in parallel the amp power would be roughly half that ... not talking a big amp.)
- How would you get these specific values ... how close can you be I wonder?
I have an old Altair that works OK with the 4db setting for me but just curious ... lot of weight to carry around just to use the first setting.
									Fixed Attentuation On A Speaker Cab?
