Greetings!
Some years ago a techie friend built me a device whereby I could use the preamp of my red-knob Twin Reverb for DI recording, without having any sound from the speakers: I'd just plug it into the speaker socket. It's a 50W/10R resistor mounted on a finned heat sink.
Is there any way I can connect this inbetween the speaker output and the speakers to reduce volume? Or do I need the complete "L-pad" 2-resistor set-up?
Can I build an attenuator from this?
- Noel Grassy
Re: Can I build an attenuator from this?
nee, If you run it between the OT and a speaker(s) you should have no problem. On second thought, I'd measure what that combined load actually was to determine if your OT needed to have the impedance switched for a more "cozy" impedance.
I probably wouldn't play with the amp cranked or too near maximum level.
Attached is a graph showing actual impedances with the various settings of the Airbrake.
Furthermore, building a "motor" as a dummy load doesn't look very difficult to build as well as incorporate into a speaker cab for the musician that has certain special needs.
- Ron Worley
Noel, well just look at you go with the fancy Excel graphs and such... And you said you have issues with the Gronkulator
Ron
Ron
- Noel Grassy
Ron, I am fingerf^cked when it comes to computer related creativity. I could put my eye out pickin' my nose, as it were.
That graph originates from Aiken's site IIRC. It clearly delineates the issues with using an attenuator so I included it.
So just connect it in series with the speakers? At the moment my speakers are 2 x 8ohm in series, amp set to 16ohms.Noel Grassy wrote:nee, If you run it between the OT and a speaker(s) you should have no problem.
It occurs to me that I also have an old 8ohm 30watt speaker with perished rubber suspension. Can that be pressed into service in an attenuator?
I guess I need a few more details of which wire to connect where! Noob on board!
IanG
- Noel Grassy
nee, Yes that's it. It goes between the amp's speaker out jax and your speaker.
