TAD vs Spragues Filter Cap Question
63superreverb
Post by 63superreverb »
I am Recapping a 1964 super reverb
I ordered two sprague 100uf 350Volt Verses the 70uf 350volt
and three sprague 20uf 600volt Verses the 20uf 525volt
but the 20uf 600volt are to big for the board/pan....
has anyone tryed the TAD 20uf 550volt would these be a good replacement for the three 20x525V and are they a good sounding quality cap??? has anyone used them??
Thanks for any help....
64' Hydromatic
v00d00blues79
Re: TAD vs Spragues Filter Cap Question
Post by v00d00blues79 »
I've used 20uF/450v and 20uF/500v caps in my Fenders with no ill effects. This was in both a '65 BF and a '68 SF(Transition AB763) Bandmaster. These both have been heavily gigged with no problems. Hell, past the screens you shouldn't have anything higher than the high 300's on the PI. :D
As for using TAD's, I haven't. I've used both Sprague and F&T, and most recently F&T exclusively.
Thanks,
Andy
63superreverb
Thanks for answering back Andy,
I seen the TAD 20x550 and thought it was the closest i could find...some say they are F&T but F&T dont seem to make a 20X550 unless TAD is putting that label on a 20X500 or 22X500..I am new to this so i do thank you for the help!
64' Hydromatic
FYL
Post by FYL »
They manufacture a full line of 550/600V caps on an OEM basis.
Cf. http://www.askjanfirst.de/kd/KONEL22.pdf
Mars Hall
Post by Mars Hall »
I just put a set of the TAD 20uf 550v caps in a 61 Concert amp. I like them, the amp sounds great.
I went through the same problem you have, with the Sprague's being to long. The 61 Concert had seven 20uf 525v caps in series. I really didn't want to change the power section to parallel 40uf caps.
I couldn't tell ya if TAD had F&T make the caps or just re-label the 20uf 500v cap. Considering TAD is in Germany, maybe they needed a higher rated cap to run on European voltages.
Telefunkin'
briane
Post by briane »
Ive used a lot of brands....tad, sprauge, nichicon...etc
To tell the truth I really cant hear a difference. Layout and other parts quality seems to have a much greater impact on tone quality. Assuming of course that the cap is in good shape (I did have 1 leaky tad out of the box).
My vote is nichicon. Beats em all on price, size, and the quality seems to be superb.
