Dual Rectifier 3 Channel build in progress
austinb
Post by austinb »
Well I started it! Here's how far along I am.
austinb
Re: Dual Rectifier 3 Channel build in progress
Post by austinb »
Here are some more pictures. Done all this in 2 weekends including making the PC boards. Used the laser transfer method and concrete cleaner and hydrogen peroxide to etch them. I used Kodak photo paper. Thanks goes out to Thomas Jeppesen for giving me the layout. Hope to have it finished soon. Waiting on more parts to come in. I will be building the cabnet next week.
jelle
Post by jelle »
Austinb,
You don't fool around! 8) Wicked build!!! :twisted: :twisted:
This must be a lot of fun.
Jelle
dehughes
Post by dehughes »
That is unbelievable. The work you're putting into that is astounding. Maybe it isn't as hard as it looks, but man...that looks intense!
Tempus edax rerum
Trigger
Post by Trigger »
Looks great. My boy wanted to build a Rectifier, but I was leaning towards a 50 watt SLO because there are turret board layouts. I can't wait to hear your build.
ic-racer
Post by ic-racer »
Wow! Looks great!
rfgordon
Post by rfgordon »
Man, that looks tremendous!
How are you doing the switching for the three channels?
Rich Gordon
texas special
Post by texas special »
Wow, very good job! :shock:
...when the blood is not water....
austinb
Post by austinb »
yes I am doing the switching for all three channels, solo, and effects loop. I have the front and rear labeling on it now. I used adobe print shop to lay it out with pictures of emblems. I printed them out on a laser printer and glued them on. pictures to follow when it get time. I have the cabnet almost ready to tolex. Still need to find some aluminume with slots for top vent and insert in the front plate. I have 3- 100 watt power transformers from organs I could use. They don't have the 60VAC tap for +15V and - voltage for bias witch is moddified for indivisul adjustment. I could figure the curren the circuits will take and use a resistor and zener to pre condition a tap off of one side of the high voltage. Switching works off of + and _ 3 volts derived from 6VAC. Witch should I use? A 360vac-0ac-360vac, 3.5vac-0-3.5vac, 5vac or a 330-0-330, 3.3-0-3.3, 5 or a 400-0-400, 3.2-0-3.2 ? I know I cant spell but don't wan't to spend time looking up words lol. Got a amp to build.
