This is nothing special. It is a two channel experiment with two Fender style tone stacks that I can switch between clean and lead settings, and a cathode follower tone stack that is only on the "lead" stage. It is about 80% done. I hope it sounds good. If not, I'll keep experimenting.:
The donor chassis was an old Carvin Valve master head that I bought for $250.00. I gutted it and started all over. I have a left over 12AX7 socket that I don't plan to use, for now anayway.....
fusionbear wrote:This is nothing special. It is a two channel experiment with two Fender style tone stacks that I can switch between clean and lead settings, and a cathode follower tone stack that is only on the "lead" stage. It is about 80% done. I hope it sounds good. If not, I'll keep experimenting.:
Effects Loop?
