New Amp: Mustang
rfgordon
New Amp: Mustang
Post by rfgordon »
Guys,
Sorry for going so long without posting some of my builds. It's been a crazy year for work travel. I just got this back from the guy who's gonna buy it so I could properly document it. It's sort of tweed-meets-BF verb.
The first tube is 6SL7 for nice fatness. I've got an adjustable boost on the first gain stage. There are also verb dwell and tone knobs on the back. I started out with two Warehouse Speakers 10s, but Charlie liked the combo better--lots of breakup on the WG 10, with smooth cleans on the Lil Buddy hempcone. This thing has god of Thunder bass--really makes the Charlie's tele snap. Instead of two inputs with different sensitivity, I put a three way switch over the input--it's easier for Charlie to work during a set than plug/unplug.
Rich Gordon
Cygnus X1
Re: New Amp: Mustang
Post by Cygnus X1 »
Very nice looking!
Adjustable gain?
Like an overdrive?
rfgordon
Post by rfgordon »
Cygnus X1,
Thanks for your compliment.
The boost footswitch grounds the cathode bypass cap on the first gain stage, but it does so after a 1K pot, so the boost effect is adjustable. The other footswitch function is reverb on/off. The reverb switch is the tip, and the boost is the ring, so if he wants, the owner can just stick any 1/4" plug into the footswitch jack to keep boost on all the time, if he doesn't want to mess with the footswitch.
The topology is very simple (sorry I don't even have this schematic hand drawn--it sort of just came out of my head as I was building).
V1a (6SL7) into a tweed style vol/tone network, then V1b (other half of 6SL7), then into a 2m2/20pF reverb take off resistor and a fairly standard BF verb circuit (12AT7 driver & 1/2 12AX7 recovery) with Dwell and tone on the back and the standard mix control on the front panel. V3b is the mixer stage, a la BF, after which is the Master Volume, then a standard LTP PI. The 6V6s are cathode bias, running into a Fender OT I got from Angela Instruments. The PT is Matts from Musical Power Supplies (275-0-275). The choke is whatever I got from CE Dist. Tube recto.
I used thin 3/8" pine plywood for the floating baffle and made the cab extra deep--about 11"--for really solid bass and great projection. The cab is dovetailed pine. The half-height back panel helps support the WG speaker on the bottom. I really like the way the blond tolex came out. I got that from BLT Sound and it was easy to work with.
At some point I need to get Charlie to record some clips with it, or if they record Alligator's show at the Charlottesville Pavilion at the end of July, I can post a song with him using this amp and/or the other one of mine he uses.
My summer project is a very simple amp with a single ended KT88 power section. It came alive yesterday--OMG does it breathe fire!! Even turned up stupid loud thru a WG 1265 it's very quiet. Kinda like a tweed champ with Godzilla's dna. When it's more "finished" I'll post photos and clips, too. It's skinned in red tolex sides with snakeskin tolex top/bottom. It's called the Dragon, mostly because that was a cool graphic I could add to the faceplate.
Rich Gordon
Cygnus X1
Post by Cygnus X1 »
I'm in the process of building a single ended with a 6550 in it.
I'm very interested in your KT88 amp!
I'm just a newb, the amp is the AX84 SEL (single ended lead).
I wanted some 80's metal gain to play with.
Tolex?
I appreciate anyone's tolex work!
I haven't gotten that far...
That is the capper, it really makes it stand out!
rfgordon
Post by rfgordon »
Here are some external pics of the Dragon. I've posted a close up of the faceplate so y'all can see the graphic. I made this thru http://www.designyourowncard.com/dyo -- click on the Engraved Signs tab. The editor works well, and when you click Add to Cart it shows the design in an inch-based grid so you can locate words, art, etc. They have a huge selection of clip art, and you can upload your own stuff, too. This face plate was only about $28 shipped. Ya gotta drill your own holes, but that's no big deal.
Though the amp shows a full tone stack and a reverb control, I think it's destiny lies without the verb. The tone is so thick and raw-- I may end up making two simple channels--one with 12AX7 and one with 6SL7. Who knows how it will end up? Some amps are just like that.....
I used a vintage PT from a Harmon Kardon DA35, so it puts 465 VDC on the KT88's plate. The choke is CEDist and the big honkin' OT is from Ted Weber.
Rich Gordon
