Help! My ODS suddenly quits working, then orks again..
Tdale
Post by Tdale »
I had a guy over today, and he was planning to buy my hybrid-a. It has always worked perfectly since the day I finished it, and indured a two and a half hour gig at high volume recently.
The only thing I've changed since then is that I replaced the 470 ohm screen grid resistors with 1.5k resistors. I also added a stereo jack for a standard foot switch, which I connected via the 5 pin xlr that was already there.
What happened was this:
The guy started playing at moderate/high volume for a while. Then suddenly there was a kind of a cracking sound, and the amp went quiet. Not dead quiet, there was still a slight hum, the hum that's always present, but no signal from the guitar.
I wrigled the peramp tube a little, and it made horrible, crackling and buzzing sounds. I removed it, and put in a new tube. Everything worked fine for about 5 minutes, then the same thing happened again. When I touched the tube, it made the same noises. I removed the tube, and put it back in again (didn't have more preamp tubes) and the amp worked fine again! 5 minutes later it happened all over again.
At this point the guy didn't really want to pay me money and bring the amp with him....:)
Any ideas about what's happening? Could it be a bad solder, or something in the pramp socket that short circuits?
Any tips are appreciated!
Tommy
CaseyJones
Re: Help! My ODS suddenly quits working, then orks again..
Post by CaseyJones »
I'm thinkin' two things.
One, you're probably on the right track with the bad solder joint. Get in there with a soldering iron and re-heat anything that's connected to that socket. Which brings us to:
Two, if you have junk Chinese sockets in there I have no sympathy for you. Don't bother re-heating solder joints if the socket is garbage anyway. Take a deep breath, unsolder it and replace it with something better.
Tdale
Post by Tdale »
I got the second from the top:
http://www.hoffmanamps.com/MyStore/perl ... =596950072
Not sure if I got them at Hoffman, but It's the "plastic" type with the shield base crimped to the socket.
Exactely what kind of socket do you recommend? I had to change a socket on another amp once...maybe I got bad sockets. Point me in the right direction, and I'll buy the socket no matter what they cost!
Tommy
