Dlator voltages
angelodp
Dlator voltages
Post by angelodp »
Do I have this correct. My build is complete and I tested it with the bulb limiter ( which did not light up ) great. Put a tube in and the LED came on. I should then read voltages at the plates pins 1 & 6
pin 1 - reads 228V to ground
pin 6 - reads 200v to ground
There is a 100k resistor on pin 6
am I ok ??
ange
gearhead
Re: Dlator voltages
Post by gearhead »
You probably will get responses here, but the Dumble section is a surer bet.
