Master vol / power scaling for Plexi clone?
jzucker
Post by jzucker »
Just picked up a rockytop JTM 45 clone and am looking for advice on the "best" MV circuit as well as possibly adding power scaling.
Thoughts?
nickt
Re: Master vol / power scaling for Plexi clone?
Post by nickt »
IME the "best" MV is none at all - no experience with power scaling but believe it sounds better than MV and is pretty simple on a cathode biased amp. (not sure what a 45 is - suspect fixed bias).
Dana is about to start selling a board that varies supply voltage and bias voltage simultaneously controlled with a single knob - a VVR (variable voltage regulator) - there's a thread on the TrainWreck forum which points back to a thread on 18Watt on the VVR (it also talks about MV's).
cheers
CaseyJones
Post by CaseyJones »
jzucker wrote:Just picked up a rockytop JTM 45 clone and am looking for advice on the "best" MV circuit as well as possibly adding power scaling.
Thoughts?
Hey Jack... I think you should throw down on a Soultone, it has the powerscaling built right in. You're the last person I'd trust with a soldering iron.
jzucker
Post by jzucker »
nickt wrote:IME the "best" MV is none at all - no experience with power scaling but believe it sounds better than MV and is pretty simple on a cathode biased amp. (not sure what a 45 is - suspect fixed bias).
cheers
Thanks. excuse my ignorance but who is dana?
Also, I'm not looking for overdrive at low volumes with the master. The master would be for just taking the edge off a really loud amp and getting some working range with the vol control. Of course, the scaling is a different matter. That *would* be for getting OD out of the amp at lower volumes. I realize that I might not need both...
jzucker
Post by jzucker »
cheers
Yes, the 45 is a lower gain version of a plexi and fixed bias.
jzucker
Post by jzucker »
Thoughts?
what's that supposed to mean?!?
gearhead
Post by gearhead »
Dana = UR12 = Major Icon on this site.
MV - Do a search as per NickTs suggestion; pretty interesting read. Do be aware that the search function here defaults to OR (as in "VVR MV" would yield threads with one or the other). Need to put the word "and" in to narrow things down.
The short answer is probably PPIMV.
BTW, how much does your JTM-45 weigh?
gearhead
Post by gearhead »
jzucker wrote:
Thoughts?
I think it's clear what he means. The real question is why he means it. Were you Lab class partners back in the day?
jzucker
Post by jzucker »
gearhead wrote:
jzucker wrote:
CaseyJones wrote: You're the last person I'd trust with a soldering iron.
i have no idea who he is and since i've never worked in a lab (other than a software one) it's highly unlikely...
I guess he's the last person I should be taking seriously... :wink:
jaysg
Post by jaysg »
Jack goes back to the early Ampage days. Street cred geek style... :roll:
jzucker
Post by jzucker »
gearhead wrote:Dana = UR12 = Major Icon on this site.
Ok, I looked it up. His board scales the whole amp. i wouldn't want to scale the preamp section. That would rob the character from the marshall circuit.
The jtm weighs around 35lbs.
fusionbear
Post by fusionbear »
I prefer to do the Fischer Type II PPIMV mod. It really helps with a JTM build. You only need to back of the volume a little to take the edge off with this mod.
Learning to learn...
UR12
Post by UR12 »
Just to set the record straight and head off some confusion, my board will do any part of the amp or the whole amp. Personally I perfer regulating the whole amp and using one knob to do everything but there are others who like the extra knob. The board will also work on fixed bias OR cathode biased amps. Even if you do the whole amp the VVR will rob the amp of nothing. On the contrary, the whole idea is to KEEP all of the character of the amp only at a lower vol.
jzucker
Post by jzucker »
fusionbear wrote:I prefer to do the Fischer Type II PPIMV mod. It really helps with a JTM build. You only need to back of the volume a little to take the edge off with this mod.
Is that the one with the dual 100k or the dual 1M? You have schematics/layouts?
jzucker
Post by jzucker »
Sounds great. When/where will this be available? Thanks for the help.
