Cleaning Pots..
FunkyE9th
Cleaning Pots..
Post by FunkyE9th »
I've been using the ones they have at Radio Shack and was wondering if DeoxIT is a better choice. Any opinions?
-FunkyE9th
leaveitalone84
Re: Cleaning Pots..
Post by leaveitalone84 »
I have been using the Radioshack stuff with lubrication for Pots. They work great for Wah's and expression pedals. Amps pots too.
I have the plain cleaner too for tubes and jacks.
From what I was told by my father (30 year electronics/avionics tech) that it is all about the same stuff. There is just different brands. He did say there was some bees knees stuff in the avionics industry but its stupid expensive.
YMMV
Ron Worley
Re: Cleaning Pots..
Post by Ron Worley »
I work in the avionics industry as well as a Sales Director.... I personally use Caig Deoxdit regular and Gold on my personal work bench...
I asked the guys in the shop what they use-
Techspray HFE Light Duty Contact Cleaner
Don't know much about it, but there's at least one industry input..
Ron
blue_dog
Re: Cleaning Pots..
Post by blue_dog »
I use a generic brand made by caig, can't remember what's it called but the same as DeoxIT. Works perfectly.
leaveitalone84
Re: Cleaning Pots..
Ron Worley wrote:I work in the avionics industry as well as a Sales Director.... I personally use Caig Deoxdit regular and Gold on my personal work bench...
Ron
Techspray HFE is the stuff my father uses all the time. There's probably 50 cans of stuff in his basement. Cans have to be thrown away at my fathers work because they are too old. :roll:
FunkyE9th
Re: Cleaning Pots..
Post by FunkyE9th »
Thanks all. I'll stick with the Radio Shack stuff for now, but will probably try deoxit later.
ampdoc1
Re: Cleaning Pots..
Post by ampdoc1 »
I ran a MI repair shop for years. I found the Caig De-Oxit to be a miracle worker for old pots. It's not cheap, but i f you learn how to apply it, a single can will last for a year or two.
ampdoc
drz400
Re: Cleaning Pots..
Post by drz400 »
FunkyE9th wrote:I've been using the ones they have at Radio Shack and was wondering if DeoxIT is a better choice. Any opinions?
-FunkyE9th
I would only use Deoxit
butwhatif
Re: Cleaning Pots..
Post by butwhatif »
Chemtronics Tuner Renu
billyz
Re: Cleaning Pots..
Post by billyz »
I have had tuner cleaners destroy pots in the distant past, ie " BLueShower" and a few from Radio Shack. I only use Caig Laboratory products now, and have never had any problems.
jem
Re: Cleaning Pots..
Post by jem »
I used to be an Audio Video electronics repair technician.
The Chemtronics Tuner Renu was for tuners...the old kind before remote controls that is. The ones with the clunky dials. We used that for multi-pole switches, not pots.
For pots the DeOxit. It's been awhile now, but if I remember correctly...red, green and blue stuff. Red last because it has the lube in it. The others to clean first.
butwhatif
Re: Cleaning Pots..
Post by butwhatif »
Never liked blueshower or any of that radio shack junk, horrible stuff imho.
The chemtronics stuff works for a lot of things, not just tuner switches. It ain't cheap, but goes a long way for the $
jjman
Re: Cleaning Pots..
Post by jjman »
The Radio Shack Tuner Cleaner I have shoots out at 50,000 MPH. Makes a mess if you don't protect the area well. The Craig Deoxit is not as bad.
austinb
Re: Cleaning Pots..
Post by austinb »
I use the old turn the pot to one end then to the other, then do that 100 times. If that don't work spray some wd40 in it and do it again.
