Is there any combination of PT primary, PT LV secondary, PT HV secondary, OT primary and secondary wires that would be harmful if -not- hooked up?  Given that there is no input signal and the rest of the amps circuit is correct (no shorts, etc.)
Meaning, what do you feel you can safely connect and disconnect to start up and trouble shoot?
						PT-OT Q
- David Root
Re: PT-OT Q
Other than the obvious one (OT sec. not connected to a load, all others connected) I can't think of one. Maybe PT connected to tube rectifier, but no load on the rectifier pins 2 & 8, that's not quite what you asked though.
						Re: PT-OT Q
OOps, forgot to specify the tubes.  Whats diff for the rectifier tube?
						Re: PT-OT Q
Can you connect the OT primary and leave the OT secondary unconnected if you don't hook up the PT secondary?
