Yet another dumb question...
My amplifier has a 2 amp mains fuse.  I have a Qualtek EMI filter (mouser part #562-857-01/46) that is rated at 1 amp at 250V.  Is it safe to use that as the input filter for my amplifier's power supply?  IOW, is it safe to assume that it would handle up to 2 amps at 120V?
Thanks!
									Thanks!
-g
						- skyboltone
Re: Yet another dumb question...
In my opinion yes.greiswig wrote:My amplifier has a 2 amp mains fuse. I have a Qualtek EMI filter (mouser part #562-857-01/46) that is rated at 1 amp at 250V. Is it safe to use that as the input filter for my amplifier's power supply? IOW, is it safe to assume that it would handle up to 2 amps at 120V?
Thanks!
I'd actually say not, but with a caveat.
Its rating is probably based on the size of the inductor wiring, so it will be limited by current rather than power dissipated in the device, i.e. a 1A limit at 250V will still be a 1A limit at 120V.
However, the amp has a 2A fuse because of the inrush current caused by the heater filaments warming up and any caps before the standby switch charging. In normal operation you'll be well below 2A, and probably below 1A.
You should try to find the data sheet and see whether there is any provision for handling a higher surge current, or whether the 1A rating is for all conditions. If it does permit higher surge currents then you'll be okay, otherwise you'll want a bigger one.
That's what I was afraid of.paulster wrote:I'd actually say not, but with a caveat.
Unfortunately, they only quote the RMS current capability, not surge. I guess the thing is cheap enough that it couldn't hurt to try it. It'll fail open if anything, so it shouldn't hurt the amp.paulster wrote:However, the amp has a 2A fuse because of the inrush current caused by the heater filaments warming up and any caps before the standby switch charging. In normal operation you'll be well below 2A, and probably below 1A.
Thanks, all!
-g
Greiswig, does that fit the standard IEC cut out on the D'Lite chassis?
And do you notice any difference in hum or noise with it installed?
Thanks, Tom
Thanks, Tom
				leaveitalone84
http://www.mouser.com/catalog/632/968.pdf
That is the mouser page with it on it.
It is a standard IEC socket.
And note that they have a 3 amp version of it that is the same size, albeit with lower inductance.leaveitalone84 wrote:http://www.mouser.com/catalog/632/968.pdf
Structo, I don't know about performance: I haven't installed it yet. But it should fit just fine. I have issues with noisy power at one place I play nearly every week. Hoping this'll help. I should have gotten the 3A version. I hate to pay for more shipping.
-g
I just checked their own page (http://www.qualtekusa.com/catalog2/emi_ ... 701046.pdf) and that states 1A RMS MAX, so I'd imagine by the MAX that there's no provision for a higher surge rating.
						- skyboltone
when winding inductors, what exactly is the difference in wire size between a 1 amp wire and a 2 amp wire?
Tom, no it does not fit. The opening would have to be almost 23mm in height for the thing to go in.Structo wrote:Greiswig, does that fit the standard IEC cut out on the D'Lite chassis?
-g
You have to wonder how marginal they wind them if they offer a 1A, 2A and 3A version of the same part.skyboltone wrote:when winding inductors, what exactly is the difference in wire size between a 1 amp wire and a 2 amp wire?
I had a few of these in my parts bin...i found them to take too much space in an Allyn or Nik chassis...
Fitting the board became problematic...
Well that sucks.greiswig wrote:Tom, no it does not fit. The opening would have to be almost 23mm in height for the thing to go in.Structo wrote:Greiswig, does that fit the standard IEC cut out on the D'Lite chassis?
I was thinking of getting the 6A one.
It's a bit less convenient, but you could always make the functional equivalent on a small board with a couple of coils and caps.
--mark
						--mark
True, or you could order 562-851-03/4 from Mouser. I think that will fit in the available space. I think that's what I'm going to do.mhuss wrote:It's a bit less convenient, but you could always make the functional equivalent on a small board with a couple of coils and caps.
--mark
-g
