Hello!
I was in the thoughts of modding my valveking head to be able to adjust the bias. By looking at how it´s done on the 5150 model I came to the conclusion of replacing resistor R250 in the attached schematic. Can anyone with knowledge tell me if this is right? What value of the trimpot would you recommend? In series with a safety resistor if the pot goes bad? I haven´t checked the bias value unmodified and I don´t know the B+ voltage either. The resistor is 39K and I belive this gives a fairly cold moderate bias.
Thank you.
Chris.
If the schematic comes out blurred, magnify it!
Valveking Mod to adjustable bias.
- skyboltone
Re: Valveking Mod to adjustable bias.
measure the voltage there and let's know what it is. I suspect you'll want to replace that resistor with somting like an 80K then parallel it with a 10k pot and a 68k resistor in series. Ground the wiper of the pot. That's gonna get you from where you are now to points higher but not lower.
Size the pot to as close to twice the resistor value as you can. Liner taper would be the best.
Wire it up as a variable resistor.
Set it to about 1/2 way to start. Adjust to taste from there.
If the pot fails it will drive the bias voltage to it's most negative ("cold") value.
Good luck,
Dave O.
Good luck,
Dave O.
most exellent guys...I´m so lucky to have ya all!
Thank´s a million!
and Merry XMass to U!
Thank´s a million!
