What in the construction or property of a transformer contributes to tone in a tube amplifier?
Sag is contributed to current supply of the HT. Voltage affects the performance of the output stage. Bias voltage affects the amount of signal arriving at the anode.
Having tested several power transformers I have observed not a little audible effect on the overall tone. I would like to hear from you all what contributes to why I am hearing tonal variation between them.
I know inductance can choke freqq. and how that a certain wind can produce more inductance over another slightly different wind. I also know variation in laminate material and core size produce various losses.
Basically, I keep hearing that Power Transformers have NO BEARING on tone, but from my own observations something is going on.
So please, enlighten me!
Power transformer effect on tone?
Re: Power transformer effect on tone?
There are several factors that affect overall tone. When a transformer is swapped out, you need to confirm that the output tubes are biased the same and the Voltages are the same throughout the amp. One often overlooked Voltage is the Heater Voltage. Don't believe me ? Try this experiment. Connect the heaters in an amp to an external 6.3VAC transformer and connect a Variac to just that transformer. As you change the Heater Voltage you'll hear the gain of the amp change by a couple of dB.
Another often overlooked factor is the FEEL of the amp and how that affects your playing. To eliminate that factor, use one of those pedals that will record your guitar's output and play it back.
I built a clone of a Trainwreck Express on an old Traynor chassis. The B+ was high at around 440V. As an experiment, I connected the Heater supply to a 6.3V transformer and used two Variacs. There is definetly a sweet spot when the B+ is lowered to just below 400V. You can hear and feel the difference.
I built two very similar expresses with different PTs, one has 395v on the plates, another 420+v. the former is sweeter and more compressed and middy, the latter a slightly more brutal and unforgiving.LOUDthud wrote: ↑Sun Oct 12, 2025 11:14 pm There are several factors that affect overall tone. When a transformer is swapped out, you need to confirm that the output tubes are biased the same and the Voltages are the same throughout the amp. One often overlooked Voltage is the Heater Voltage. Don't believe me ? Try this experiment. Connect the heaters in an amp to an external 6.3VAC transformer and connect a Variac to just that transformer. As you change the Heater Voltage you'll hear the gain of the amp change by a couple of dB.
With higher voltages you normally get a quicker response, less compression, later distortion and more brightness
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
As the current Output of any given PT starts to reach its limit then the tone of the amp will start to change.
The point where the power supply voltage starts to sag is where you have maxed out the current available from the PT.
This is also the point where the filament voltage will sag with the resulting lowering of the gain out of each stage.
Depending on what you want out of the amp this change will be good to your ears and to others it will not.
There’s also a big change in play feel at this point, but your just asking about tone.
You might like to read a series I started on the basics of transformers, here:
https://ampgarage.com/forum/viewtopic.p ... cs#p467963
Transformers can be modeled very accurately with the idea of an ideal, perfect transformer hidden inside the real-world transformer and various imperfection components added in series or parallel with the primaries and secondaries.
You are getting good comments from the other posters about things that can cause changes in sound when the transformer voltage changes, for both the high voltage supply and the heater voltage.
More accurately, sag results when the amount of current pulled from the PT->rectifiers->filter capacitor changes the plate supply voltage. The PT and rectifiers both have what amounts to an internal series resistance that causes the voltage on the first filter cap to sag lower by limiting how much they recharge the first cap when the rectifiers turn on. The first filter cap value has an effect, because for a given capacitor size, the average high voltage sags because of increased ripple voltage. You can "fix" that by using a bigger filter cap, if your vacuum rectifier can stand the current pulses. All of these affect how much the plate voltage sags, and that as noted causes audible changes in the tone.Sag is contributed to current supply of the HT. Voltage affects the performance of the output stage.
That's not how I'd state that. Bias voltage affects the overlap in conduction of the two output polarities. It can change crossover distortion products, which CAN be heard. I don't know how the amount of signal arriving at the anode (presumably of the output tubes?) would be affected by that.Bias voltage affects the amount of signal arriving at the anode.
To play just a little dumb, everything contributes to this. plate voltage, filter capacitor size, transformer internal resistance, rectifier resistance, bias voltage change as the PT is more heavily loaded, and many more things. It's really a little too simplistic to blame all of these on the PT.Having tested several power transformers I have observed not a little audible effect on the overall tone. I would like to hear from you all what contributes to why I am hearing tonal variation between them.
The PT's leakage inductances cause a changes in the sag in the plate voltage on the first filter cap. It's a time-domain effect caused by the rectifiers turning on a bit earlier and off a bit later on each half cycle. You get a lower average plate supply voltage, but with less ripple on it. Yes, special winding techniques do make for different leakage inductances. But in today's world, no PTs are wound with the special lower leakage techniques, ever, as a result of the economics. Economics also dictates that very seldom is an odd core material or bigger core size used. Sure, they could theoretically be used, but there's almost no difference in ordinary transformer iron, and hasn't been for decades. Core size is picked to allow the absolute minimum amount of iron and copper to be used to ---just barely--- make the desired voltage and current. There are variations that are theoretically possible, but the iron hand of economics has squeezed out all the fancy stuff. It's one aspect of MBA Disease's race to the bottom.I know inductance can choke freqq. and how that a certain wind can produce more inductance over another slightly different wind. I also know variation in laminate material and core size produce various losses.
You're right, something is going on. But it's not as simple as one transformer versus another. The devil is very much in the details, and things other than "tone" dictate what is available to you as alternate transformers..Basically, I keep hearing that Power Transformers have NO BEARING on tone, but from my own observations something is going on.
Mark Twain
Mark Twain
Don't 50Hz transformers have a slightly bigger core ? In the USA, the vast majority of Fender amps have only a 120V primary. Can we assume they are intended for 60Hz only ? How much of a temperature change would you expect going from 60Hz to 50Hz ?
Famously, Neal Young was hearing differences in his amps when they were operated on 50Hz while on tour. Was it just the ripple frequency coming through when the amps were clipping ? I think he changed over to using something like a UPS so the amps would be operated at 60Hz no matter where he played.
Tone is entirely subjective.
However, there are good and less good power transformers. I have a couple of New Sensor Corp Fender replacement transformers, described as 50-watt bassman, tweed bassman, super reverb, etc direct replacements.
However, the core stack is a lot shorter, fits the hole right and has the right number of wires. It is missing the electrostatic shield. (the copper tape strap around the core). They also seem to "float" more, meaning less regulated. Unloaded, they put out more voltage than the originals and loaded, they put out a bit less. My theory is they save a bit on skinny cores and use thinner wire and an extra wind or two. (RG knows a ton more about transformers than I do).
They are "good enough" as repair parts as they'll make it go again. Not ideal though.
50hz cores are bigger, and it's a direct result of the lower frequency. For a given core, the ability to stay out of saturation means that the voltage and frequency are inversely proportional. For a 60Hz core that's running between positive and negative saturation by a given voltage will begin to saturate if you feed it the same voltage at 50Hz. This is all pretty linear/proportional, so the same core that's fine at, for instance 120Vac 60Hz will be driven to the same extent of saturation with a 50Hz voltage of 120 * 50/60 = 100Vac.
Transformer designers will design a 50/60Hz rated PT for 50Hz 120Vac. This will work fine at 60Hz 120Vac, with perhaps a hair lower loss by staying a little further from saturation and having more area to convect/radiate heat out of. In the USA market, my guess is that they are all designed for 60Hz, the economics demon squeezing them into not using one penny more iron or copper. But if you had to do a 50/60Hz transformer, you design it for the lower frequency.
The real criteria is how much you let your iron saturate. The common transformer irons saturate softly, so there is some play in how far you can let them go into saturation. It then becomes a heat transfer design question, and that's probably settled with a number of prototypes and duels at sunrise between the engineers and accountants.
I personally would never run a 60Hz transformer on 50Hz. It might survive fine, might have different voltages (saturation means not all the turns-ratio voltage gets from primary to secondary) and would certainly have more primary current and heating. I'd say that all USA Fenders are designed for 60Hz.
I think what he was hearing was real. His amps were/are probably USA or Canada models, and likely designed for 60Hz. Running them on 50Hz, even with a step down transformer would make the plate voltages a bit lower, they'd run a bit hotter, and any ripple leaking in would be 100Hz, not 120, and that would sound noticeably different. It would probably have been cheaper to trade out the PTs for 50Hz rated ones.Famously, Neal Young was hearing differences in his amps when they were operated on 50Hz while on tour. Was it just the ripple frequency coming through when the amps were clipping ? I think he changed over to using something like a UPS so the amps would be operated at 60Hz no matter where he played.
Mark Twain
Mark Twain
+1. Often the power supply affects the tactile feel and response more than the tone directly.Stevem wrote: ↑Mon Oct 13, 2025 9:11 pm As the current Output of any given PT starts to reach its limit then the tone of the amp will start to change.
4x12" w/H75s
4x12" w/H75s
I keep getting whacked by the "too many request" problem on the board.
The "less good" power transformers I've got in my pile of unused parts are notably smaller cores and lack a flux-band and probably the electrostatic shield. They also seem to "regulate" more poorly than the heavier part numbers they replace, meaning the voltage is higher unloaded and drops more as load is imposed. Clearly, they're cost cutters.
My suspicion is that they skimped on the iron and put a few extra turns of skinnier wiring on the secondaries to shave a few pennies on the per-unit costs. I think that way, they could be something passable to replace the original part number at a lower cost.
But I think the less steady voltage, the lack of shielding and a flux band, would affect tone with the modulation effects of less stable voltage, and the lack of e-shield allowing more line-noise in and the lack of a flux-band allows more radiated hum into the amp.
