Best amp cradle?
Best amp cradle?
I have gotten to the stage where I’m sick of balancing amps on wooden blocks etc.
I was wondering based on your experience, which amp cradle works the best?
Thanks for your assistance.
Yours Sincerely
Mark Abbott
Mark Abbott
sluckey
Re: Best amp cradle?
Lot of good ideas in this sticky thread.... https://ampgarage.com/forum/viewtopic.php?f=6&t=27171
Here's my favorite.... https://sluckeyamps.com/cradle/cradle.htm
- pottedplant
biased i see lolsluckey wrote: ↑Mon Apr 07, 2025 5:36 am Lot of good ideas in this sticky thread.... https://ampgarage.com/forum/viewtopic.php?f=6&t=27171
curious, has anyone here ever used rolls of blue tape? I love how the power transformer bell fits inside the opening just enough to stay put.
I have done the blocks like you & I have from tacked together a dedicated-sized riser base (a bottom & two end blocks) from time-to-time, but I do like using a pivoting chassis cradle the best.
The commercial ones are pretty pricey, so I made a stripped-down & simplified version, mostly out of scrap, that probably works nearly as well.
Mine uses just one locking knob on the pivot (no radiused routs) & hasn't been an issue.
I borrowed the length adjustment idea from someone online (not sure who), that uses readily available C-channel made for woodworking jigs for changing the spacing between the ends. One end is fixed & the other end slides in the clamping channel.
A wooden key on the bottom of the adjustable end sits in the channel & keeps it aligned.
Harder to describe than it really is.
Mine is a bit shorter than I would like, but the pieces were in stock. I might make a second longer one at some point.
Thanks for your replies and yes the commercial ones are quite pricey.
There are nice looking amp cradles there. I will have to go down the commercial route as I don’t have wood working tools or an area to do woodwork. The most obvious is I know nothing about woodworking.
Yours Sincerely
Mark Abbott
Mark Abbott
I threw this together , basically a copy of the mojo cradle. Scrap pieces of plywood . Works pretty well.
I'm getting 404 errors on anything related to to your site. I remember having this issue in the past, but I can't recall how I got around it.sluckey wrote: ↑Mon Apr 07, 2025 5:36 am Here's my favorite.... https://sluckeyamps.com/cradle/cradle.htm
sluckey
2 others liked this
The website is gone. Here's my simple cradle...carlsoti wrote: ↑Mon May 19, 2025 12:50 pmI'm getting 404 errors on anything related to to your site. I remember having this issue in the past, but I can't recall how I got around it.sluckey wrote: ↑Mon Apr 07, 2025 5:36 am Here's my favorite.... https://sluckeyamps.com/cradle/cradle.htm
