airbrake for a 10 watt or less amp
wsaraceni
Post by wsaraceni »
im building a single ended (champ style) amp and want to have an airbrake built right into the chassis if possible. i dont have room for those huge resistors and im not sure if i need them. just wondering if there is a way to make one work and add the controls to the front panel without introducing noise. what parts can i substitute for the large resistors and still have a good working design?
wsaraceni
Re: airbrake for a 10 watt or less amp
Post by wsaraceni »
also, how hard is powerscaling a design like a champ instead?
Tubetwang
Post by Tubetwang »
wsaraceni
Post by wsaraceni »
thanks. how would i hook that up with a bypass switch? and will there be any noise added when running that from the front panel to the speaker jacks in back? i want to use the front panel since i have a lot of extra holes and dont want to reach in the back of the amp all the time to get to the controls.
Tubetwang
Post by Tubetwang »
You may mount it on the front with output tranny to l-pads and l-pads to speakers (instruction on the box). There should'nt be a problem with noise.
benjoi
Post by benjoi »
I use the 50watt L-Pad with my 18watt and it sounds good. Actually I usually run it 1/2 to 3/4 volume just to smooth out the highs. It sounds pretty good down to about 1/2 on the volume, then just ok down to 1/3 any further it starts loosing alot of definition and just sounds too muddy to even play. Great deal though.
mooreamps
Post by mooreamps »
wsaraceni wrote:also, how hard is powerscaling a design like a champ instead?
I'll PM you my schematic if you a serious about installing one inside a champ. My circuit does not use those hugh resistors and it will power scale the output tube.
-g
