Apologies for the seemingly simple question in advance.
I have a newly acquired 1964 Vox AC10. Original electrolytics so changed them out and installed a fuse.
I was comparing the amp with the schematic and noticed something that I could use some help in trying to understand.
I see that pin 5 (heater) on the ECF82 appears to be grounded.
The schematic shows pin 4 grounded:
Is there an issue with this amp having pin 5 grounded instead of pin 4? I'm not sure if the schem has an error or the amp was wired incorrectly but I'm fairly confident it doesn't matter for the other tubes but pin 9 on the 12AX7 is confusing me here and overall I don't think it matters whichever pin is grounded but want to confirm.
More importantly, *why* do the filaments need to be grounded?
Thank you for your patience, wisdom and understanding.
Chris
