Masco ME-27 schematic
shane
Post by shane »
Hi folks
Has anyone got a schematic for a Masco ME-27? Or maybe give some info about them, like for instance what phase inverter they used.
Cheers
Shane
jabguit
Re: Masco ME-27 schematic
Post by jabguit »
Masco_me-27-sch.pdf
Jack Briggs
Briggs Guitars
shane
Post by shane »
Thanks Jack 🙂👍
sluckey
Post by sluckey »
The amp uses a paraphase inverter.
shane
Post by shane »
Thanks Sluckey🙂👍
Does anyone know the transformer specs for these amps, or where I might find out? 😁
Cheers
sluckey
Post by sluckey »
Are you building one, or repairing one, or just curious? Just what are your intentions?
shane
Post by shane »
Thinking of building something closely based on one.
I saw Rhett Shull's YouTube post about his, the one modded by Eli Lester and one done by a guy over here in the UK, and thought they sounded great.
Cheers.
LOUDthud
Post by LOUDthud »
Note that the schematic specifies the 6L6G. That's the earlier version with the 19W rated plate. Not the 30W rated 6L6GC. The RCA lists a 6000 Ohm OT in it's examples with similar Plate and Screen Voltages for a 31W output.
I don't believe the 11V reading on the cathodes. Should be more like 21V.
shane
Post by shane »
Thanks Loudthud.
Yes that cathode voltage must be wrong, its even a wee bit low for EL84's never mind 6L6G.
Cheers👍🙂
