Drop-in Tremolo oscillator design
nuke
Post by nuke »
I've pondered the idea of replacing the tube based tremolo oscillator in my Fender Deluxe Reverb amp for a long time, in order to make use of the tube and socket for something more interesting. The two sections of 12AX7 have zero effect on audio, and are not connected to the audio path at all. The first section simply performs the low-frequency oscillator function, the second section merely flashes a neon light bulb on and off in the tremolo "roach". The only part of the tremolo system that's in the audio path is the Light Dependent Resistor in the tremolo opto-coupler.
To make it practical, I wanted it to retain the 3M reverse-audio panel control, and the function of the foot pedal, in particular, absence of the pedal leaves the effect off. Thirdly, I want to power it from some source already within the amplifier's circuitry and easily fit into the space in the chassis.
I've seen R.G. Keen's solid-state replacement for Fender Tremolo circuit.
http://www.geofex.com/Article_Folders/s ... remolo.htm
Clearly, a lot of very hard work went into this design, a product Keen's innumerable talents. :)
I decided against implementing this for a few reasons, complexity, parts count, cost and inertia on my part. Thus a project undone for a while now.
I happened upon an unexpected inspiration from Peavey, the mid-1990's Transtube circuit, patented by Sondemeyer et-al. The circuit is the Peavy Transtube 212. It is very curious in the use of multiple transistor preamp stages, implemented as discrete transistor pairs in an unusual common-emitter amplifier configuration. Only after reading the patent declaration, did I grasp what they were thinking.
patent link:
http://redirect.viglink.com/?key=71fe21 ... 2752B1.pdf
Schematic link at item #62:
http://redirect.viglink.com/?key=71fe21 ... matics.htm
I was curious enough about this topology to breadboard out an example of the stage to play with. It turns out to be a really interesting circuit. The darlington pair presents a high gain, high input impedance amplifier, which mimics those characteristics of a tube amplification stage.
Getting back to the tremolo idea, the high impedance feature is important, if you want to retain the same LFO range and the same 3M reverse audio taper pot used in most blackpanel and later Fender amp circuits. This circuit also functions on a relatively high Vcc, of about 30v and doesn't require much current to function. This supply level is easily derived from the "C" winding (bias supply) tap of the standard Fender style power transformer.
The presented circuit oscillates reliably in the range of 2.5hz - 9hz, using a 3M-RA pot to control it. The waveform output is sinusoidal and with a Vcc of 30 volts, produces approximately 27 volts peak-to-peak output. It's also small enough to easily render on a small circuit board. It isn't particularly picky about transistors. I built it out of "junk box" small NPN. I find it works best with moderate gain (hfe ~250) small signal transistors, but substituting random matched and unmatched transistor pairs works fine with no difficulty. It is pretty robust in other words.
Now, we're in business!
With this level of output, configuring the oscillator with a suitable output stage, it could drive an LED, or the existing neon bulb in the tremolo opto-coupler, or coupled to the bias voltage to implement a bias-wiggle tremolo.
My plan is to implement this on a small circuit board, to replace the usual bias-supply tag board. It would supply the negative bias supply normally produced on the tag board, along with the complete transistorized oscillator circuit and whatever output stage is desired.
I think a tremolo roach with a red LED in it would be ideal, but a small open-drain MOSFET of suitable voltage can easily drive the existing neon bulb in the opto-coupler. Similarly, an emitter follower or some such should work well for bias modulation, as found in earlier Fender amps.
I haven't worked out the footswitch control method entirely, but connecting/unconnecting ground from the legs of the phase-shift network does have the desired function. I think I'd like something cleaner than that.
The goofy thing is that I can't seem to get ngspice (in KiCad) to properly simulate the circuit. The simulation doesn't at all match the breadboard. Probably something dumb on my part, but I'm not a SPICE guru.
Here's the basic circuit:
Re: Drop-in Tremolo oscillator design
Very cool. I hope you do include an LED and LDR, so the unit is a complete trem.
lonote
Post by lonote »
I have gone part way down that rabbit hole myself.
As you point out, the LFO is independent of the audio path, so why not save a tube & the space required?
I got as far as building a MOSFET LFO, partly inspired by another RG Keen paper, "MOSFET Follies" http://www.geofex.com/Article_Folders/m ... tfolly.htm
The MOSFET LFO I built was essentially as simple as your schematic & worked well, though I did not have as much luck with a MOSFET follower stage that I tried, for a complete trem section. I started to integrate a Vactrol unit (like Sluckey's Trem-O-Nator), but kind of stalled out there & haven't gotten back to it.
Getting a working SS trem circuit for tube manipulation is high on the list for this winter's projects.
Tangentially, you might be interested in this other circuit I have bookmarked; https://el34world.com/Forum/index.php?topic=31700.0 It is an add-on for a Fender-style trem (Princeton in this case) that uses the existing LFO to manipulate a simple add-on pitch-shift circuit so you have both Vib & Trem, in the spirit of a Magnatone.
I haven't built it, but the OP's sound clips were encouraging. I have only gotten as far as laying out an add-on board for that one. Hoping to try that one out over the winter as well.
