Anyone tried a LarMar MV with bias-vary trem?
lonote
Post by lonote »
I am drawing up a 6G3-inspired amp for an over-winter project & wouldn't mind keeping the bias-vary trem, but would like to include a LarMar PPIMV. I can always try just building it & see how it works, but wondered if this is ground already covered?
Power section will be the typical LTPI & PP 6V6s (or equivalent power tube, might try an odd-ball).
Roe
Re: Anyone tried a LarMar MV with bias-vary trem?
Post by Roe »
works fine but you get a bit more trem intensity as you turn down the master volume
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
lonote
Post by lonote »
Roe wrote: Sun Oct 13, 2024 2:50 pm works fine but you get a bit more trem intensity as you turn down the master volume
Excellent, thanks for that information. That would not be an issue.
As both features manipulate the same area, I wasn't sure if there might be some weird interaction beyond my level of understanding.
Roe
Post by Roe »
lonote wrote: Sun Oct 13, 2024 4:27 pm
some amps benefit from this diode mod: https://www.tdpri.com/threads/6g2-trem- ... x.1154195/
4x12" w/H75s
