The Hammond OT uses a smaller bolt spacing than the chassis. (It seems the chassis spacing is correct, but the OT is smaller than most others sold for this application).
I thought it would be easy to drill a 3/16 hole in chrome plated steel plate so I tried and failed, and then failed again even with a brand new carbide drill bit for stainless. Now I read that this means the potential hole is probably 'work hardened' and no amount of drilling or new bits will drill it.
Looking at the OT in place with the bolts I think I might be able to mount it as is, perhaps with 'some type of washer' to hold the OT hole as its tightened down, or perhaps there is another way? The legs of the OT seem to sit a little above the chassis so there is plenty of room for washers or flanges to go under both legs if need be.
Any suggestions as to how I can get this securely mounted after one (more) visit to the hardware store?
