Matchless Lightning with EL34 complete Schematic
stinga11
Post by stinga11 »
I've been wanting to build a Matchless Lightning with EL34 tubes for months, and in my analysis of how to find the correct voltages, and even more complicated, how to find the correct transformers, I found the schematic for the Bad Cat Hot Cat 30. So what did I do? I used the power transformer from a Deluxe Reverb Reissue that gives me (325V-0-325V 207mA) & (6.3V 4.5A), the output transformer is from a Bandmaster with 4,000 impedance in the primary and 40 watts, and a choke from an AC30.
I wired the tonestack in Fender/Marshall style to avoid interaction with the bass that the Matchless tonestack inherited from Vox.
The values of the cathode resistors of the power tubes are not correct but I have not yet calculated the correct value, I just put any value so as not to leave it blank.
Please check it out and give me your advice or warnings. Thanks in advance
New version, I changed the power transformer for one from Bassman, the 290DX has the same voltage 325V-0-325V but in this case I have 230mA instead of 207mA. Now I have diode rectification to make the most of the voltage.
The schematics I used are the Matchless DC30, Matchless Lightning, and Bad Cat Hot Cat 30.
Re: Matchless Lightning with EL34 complete Schematic
Neato.
1st thing the 325 might be a little low (even for me) I look for 370+ and would rather it be a target of 400.
Bandmasters want Bassman output. You might actually want to consider Amp Parts Direct JTM45 PT (heyboer) and Bassman output (heyboer).
400v and 3k8.
Send needs cap to block DC at jack... couple other things. I'll leave room for other replies. :)
stinga11
Post by stinga11 »
Reeltarded wrote: Mon Mar 25, 2024 2:42 am 1st thing the 325 might be a little low (even for me) I look for 370+ and would rather it be a target of 400.
Reeltarded wrote: Mon Mar 25, 2024 2:42 am Bandmasters want Bassman output.
Reeltarded wrote: Mon Mar 25, 2024 2:42 am Send needs cap to block DC at jack...
Have you ever seen the schematics of the matchless or the BadCat Hotcat?
maxkracht
Post by maxkracht »
stinga11 wrote: Tue Apr 02, 2024 11:51 am Have you ever seen the schematics of the matchless or the BadCat Hotcat?
If you expect us to reference schematics, you should post schematics.
I agree that your transformer choices are a bit strange, el34s could load down a power transformer that expects 6v6s so you might not get your expected voltage. How did you get the 325 number in the first place? Why use el34s if you are running them at 6v6 voltages?
Post by Stevem »
I can't see why a 4 amp fuse is needed.
Your speaker jack should be of a shorting type when there's nothing plugged in and having a 150 ohm 7 to 10 watt across it is a good & cheap no load save the OT way to go.
Your output tube plate voltage will be on the low side especially once you factor in the cathode voltage that the tubes will idle at.
stinga11
Post by stinga11 »
maxkracht wrote: Tue Apr 02, 2024 2:53 pm If you expect us to reference schematics, you should post schematics...
You are absolutely right, sorry. I just added the original schematics. Thank you
stinga11
Post by stinga11 »
maxkracht wrote: Tue Apr 02, 2024 2:53 pm How did you get the 325 number in the first place?
In the Bad Cat schematic the voltage that appears is 321V.
maxkracht
Post by maxkracht »
stinga11 wrote: Tue Apr 02, 2024 4:04 pm
Gotcha, the way you wrote this confused me.
stinga11 wrote: Mon Mar 25, 2024 12:22 am I used the power transformer from a Deluxe Reverb Reissue that gives me (325V 207mA) & (6.3V 4.5A)
Its a 650vct or 325-0-325 transformer. On a deluxe reverb, that gives you somewhere around 420v dc to play with, I would expect less with el34s, and as Steve mentions, you lose more voltage on the cathode resistor(s). Unless you know all the specs of that badcat transformer, I wouldn't count on hitting the same numbers. I also wouldn't count on the badcat being well designed.
stinga11
Post by stinga11 »
maxkracht wrote: Tue Apr 02, 2024 4:31 pm Its a 650vct or 325-0-325 transformer. On a deluxe reverb, that gives you somewhere around 420v dc to play with, I would expect less with el34s, and as Steve mentions, you lose more voltage on the cathode resistor(s). Unless you know all the specs of that badcat transformer, I wouldn't count on hitting the same numbers. I also wouldn't count on the badcat being well designed.
Would it be better to use the transformers from a JCM/JMP? Would the schematic work for me? My english is so bad, sorry for that.
maxkracht
Post by maxkracht »
Your english seems fine to me. The deluxe transformer might be ok, I haven't tried it with that setup so I don't know for sure. My only concern is your voltage could be a bit low. I would probably go with something meant for 6L6 or EL34. Maybe a Bassman transformer? If you are looking at Marshall replacement transformer and you want to use a tube rectifier, make sure there is a centertap on the high voltage winding and 5v for the rectifier heater. Some JCM use a bridge rectifier.
wpaulvogel
Post by wpaulvogel »
A JTM45 power transformer SHOULD have 350-0-350 and that would get you 440-450 volts DC. They make for a great EL34 transformer. If you’re using cathode bias, you’ll be needing about 35-40 volts cathode voltage and you will subtract that from the B+ for figuring out power output. It still should be about 45 watts clean. I’d use fixed negative bias myself. It’s not going to react like EL84’s.
Sold out for now, but this is my choice for the voltage range I like on my amps.
400v on tube rectification.
https://shop.amppartsdirect.com/collect ... ansformers
amimaster
Post by amimaster »
Reeltarded wrote: Wed Apr 03, 2024 5:55 pm Sold out for now, but this is my choice for the voltage range I like on my amps.
I'm also thinking about building a similar amplifier. However on TAD they used to list this as Main Transformer: https://www.tubeampdoctor.com/en/mains- ... ghtning-15
which is a 280-0-280. It is sold-out so I'm thinking about a replacement, but now I'm unsure of what plate voltage I want...
TUBEDUDE
Post by TUBEDUDE »
Since you're using cathode bias, I'd link the heater center tap to the power tubes cathode.
