You never know!
You never know!
Post by Stevem »
Brand new Marshall 100 super lead with the pin 3 cathode cap wired in back wards.
Re: You never know!
You'd think with the arrows ot wouldn't be to hard to get right.
I can always tell when.one of the local Ukrainians have worked on a house because the light switch says no instead of on. :D
TUBEDUDE
Re: You never know!
Post by TUBEDUDE »
Stevem wrote: Fri Mar 01, 2024 12:18 pm Brand new Marshall 100 super lead with the pin 3 cathode cap wired in back wards.
So that's why they sound like that!
FUCHSAUDIO
Re: You never know!
Post by FUCHSAUDIO »
Peavey made tons of 5150's with the cathode caps installed in reverse....I can only imagine how many.
Re: You never know!
Post by Stevem »
I can see how this could happen with the Marshall that’s hand wired because the cathode resistor I would assume was soldered across the cap and then both soldered in as a assy, but when your installing a cap on a board that’s marked for correct installation then that’s a real screw up!
