A friend and I are working on our second amp build and I was wondering about replacing the tube rectifier with solid state. We're building an AB763 Vibrolux.
I've read the Lazy Amp Tech tube rectifier thread and it suggests that this is ok given I add dropping resistors in series before the diodes I use for the rectifier.
I have a couple of concerns I wanted to ask before trying to attempt the math myself as I haven't done anything this involved since grade 12 physics (to be fair this is probably more involved than that was).
I've been comparing the schematic of the Vibrolux to the AB763 Bandmaster schem and the values are 320VAC which becomes 440V after rectification. There are 2 problems here, one being the transformer for the Vibrolux has a 325VAC secondary and the other being the B+ with the GZ34 is 415V. It looks like I'll have about 455V B+ if I just replace the GZ34 with diodes, so how should I go about dropping this to 415V? The inline dropping resistor was suggested in the forum I mentioned, but I'm not sure what value would make sense in this context (use ohms law?), or even if inline resistors make more sense than using a resistive attenuator circuit...
Another thing that concerns me is what to do with the 5V 3A secondary for the filament of the power tube. Should I just leave it disconnected? If anyone has any cool ideas for it that would be appreciated (I've seen some stuff about relays but I haven't read much about it). If not I think I'll just leave them disconnected.
I'd love to hear people's thoughts and advice, as I'm sure your experience will be insightful for my project and helpful in preventing me from lighting my new amp on fire
- Wyatt
