...that doesn't truly suck the life out of your sound??
I can safely say I would not be using it with any extreme cut...... Thnx
Power Soak Under $200.....
pullshocks
3 others liked this
Re: Power Soak Under $200.....
2nded. Brilliant bit of kit. I’d even consider building it ‘in’ my next amp instead of power scaling / VVR etc.pullshocks wrote: ↑Sat Dec 23, 2023 7:07 pm I built one of these and it works great
https://www.marshallforum.com/threads/s ... ing.98285/
https://www.marshallforum.com/threads/s ... st-1879755
These are great, but not a subtle cut. It a a pretty big initial knockdown of signal, so if you are looking for something to pull your volume down a bit, it could be too much. I built this circuit for live playing and found it way too much
