Relay mechanical noise level - (video)
				timrobertson100
Hi folks
This is my first use of a relay, so before wiring in the signal board, I wanted to test it.
It's getting a clean 12V supply and it works, but I'm surprised at the level of mechanical noise. A quick video is attached - for reference, it's louder than you hear toggling the manual switch on the front.
The relay I bought is this Finder one which I see is rated up to 2A at 230VAC.
I hadn't paid enough attention when ordering and see there is a Fujitsu "signal" one which is rated at 0.5A at 120VAC.
I guess I bought one intended to switch power circuits and not signals - before I order anew are the relays rated at lower power much quieter, please?
Thank you
Thank you
Re: Relay mechanical noise level - (video)
The noise level a relay makes when closing has nothing to do with the current and voltage rating that it's closed contacts can handle.
I have found that if you have a ton of extra current on hand then what the coil of the relay needs to close itself then the hand clap of that action will be louder maybe then it should.
The Omron relays commonly used in The Dumble circuits as described here are pretty quiet, hard to hear over the noise of the rear panel mini toggle switches.
				timrobertson100
Thanks Steve - that is very helpful to know.Stevem wrote: ↑Thu Dec 21, 2023 11:20 am The noise level a relay makes when closing has nothing to do with the current and voltage rating that it's closed contacts can handle.
I'm powering the relay using the typical Dumble circuit, but at 12V, driven from a spare 8VAC winding I have, and the foot and toggle switch just make or break the ground connection.
Is there anything you'd suggest changing, or is this pretty much what is expected, please?
				timrobertson100
Thanks, Martin (I was writing as you posted). I know this will be quieter when it's all buttoned up but it just seemed (to this relay newbie) unexpectedly loud.martin manning wrote: ↑Thu Dec 21, 2023 12:03 pm The Omron relays commonly used in The Dumble circuits as described here are pretty quiet, hard to hear over the noise of the rear panel mini toggle switches.
Maybe I'll add some Omron's on my next order and experiment.
				sluckey
                                            2 others liked this
Sure it does. High current rating for contacts means the contacts must be physically larger. The bigger mass of the contacts requires a bigger armature. Bigger armature makes more noise when closing. For extreme example, the 30 amp contactor in your A/C compressor circuit make a very noticable "clunk", while small signal relays are hardly audible.
Reed relays are essentially silent, although they are expensive and hard to find in SPDT, even harder to find in DPDT. Not a leading choice, but available.
Relays noted as "low signal" are physically smaller, and likelier to be mechanically quiet. I have used the Panasonic TQ2 series, the Kemet EA-2 series, and the Fujitsu FTR series in my prototypes and in commercial effects. These are all in a 10 pin, low profile package that is about half the size of the one you're using. These are very quiet, and usually inaudible inside a metal box.
Mark Twain
						Mark Twain
+1 for the Omron. These are very quiet and I have used this brand for years in industrial applications with very reliable results.timrobertson100 wrote: ↑Thu Dec 21, 2023 12:08 pmThanks, Martin (I was writing as you posted). I know this will be quieter when it's all buttoned up but it just seemed (to this relay newbie) unexpectedly loud.martin manning wrote: ↑Thu Dec 21, 2023 12:03 pm The Omron relays commonly used in The Dumble circuits as described here are pretty quiet, hard to hear over the noise of the rear panel mini toggle switches.
That said I would have no issue with putting the Fujitsu relay you linked to in my amp. The specs are similar to the Omron.
Glenn
I solder better than I play.
				timrobertson100
Thanks Glenn, RG, Sluckey
I’ll replace this with a different type down the line then.
Great point Sluckey!
Never looked at it like that.
