LARGE 6V6??
zozoe
LARGE 6V6??
Post by zozoe »
G'day.... Has anyone ever seen 6V6's that are this tall (see pic)....? The amp's maker, but not the previous owner, said the amp performed well with them, & they could be Chinese oddballs.... They're totally unmarked, and the one on the far right, or on top, is my standard sized Tung-Sol 6V6....
many thanks ॐ💃
Re: LARGE 6V6??
Post by Stevem »
More then likely Russian made I would say.
The Chinese would never waste money / send profit down the drain by using extra glass to make a tube.
Ten Over
Re: LARGE 6V6??
Post by Ten Over »
zozoe wrote: Thu Aug 10, 2023 3:39 pm G'day.... Has anyone ever seen 6V6's that are this tall (see pic)....? The amp's maker, but not the previous owner, said the amp performed well with them, & they could be Chinese oddballs.... They're totally unmarked, and the one on the far right, or on top, is my standard sized Tung-Sol 6V6....
If they are totally unmarked, what would make you think that they are 6V6?
pdf64
Re: LARGE 6V6??
Post by pdf64 »
Try measuring how much heater current they draw. My guess is that it’ll be more like 0.9A each than 0.45A :)
bepone
Re: LARGE 6V6??
Post by bepone »
not russian.. russian version is 6P6S, short bottle black glass
zozoe
Re: LARGE 6V6??
Post by zozoe »
[/quote]
[/quote]
ONLY because it's what the amp calls for, and that I bought it from the builder, RC Davis, but he wasn't the last owner... He said it works well, but I wanna stay on the side of another owner's errors, and give it what's truly called for..... ॐ💃
chumchai
Re: LARGE 6V6??
Post by chumchai »
Looks like a Russian 6P3S (6L6 derivate)
zozoe
Re: LARGE 6V6??
Post by zozoe »
I'm gonna ditch them for something I'm certain about...
Thnx all!!
bepone
Re: LARGE 6V6??
Post by bepone »
some pics from top will help.. can be yes 6P3S, this is thenclose to 6L6 (not GC version) or 5881 tube - 19W dissipation, slight overkill for 6V6
pdf64
Re: LARGE 6V6??
Post by pdf64 »
chumchai wrote: Thu Aug 10, 2023 11:18 pm Looks like a Russian 6P3S (6L6 derivate)
RCA set up a valve production facility and provided training for the Soviets in 1937. So rather than being a derivative / reverse engineered 6L6, the 6P3S (or at least what became the 6P3S) may have been a fully licensed / approved 6L6
https://en.m.wikipedia.org/wiki/Russian ... signations
Re: LARGE 6V6??
Post by Stevem »
They would then be a 6L6B and the in line exit of all the internal leads limits the voltage that can be placed on them without arcing.
