Mercury Magnetics Transformer Wiring Question
newAmpBuilder
Post by newAmpBuilder »
Newbie technical question. I'm replacing the power transformer in my Ceriatone OTS 50 with a Mercury Magnetics CER-OTS550-P and don't know what to do with wiring the 60V bias supply. There are two gray leads. I don't know whether to float one end or ground it and don't want to blow anything up. I attached the Wiring diagram from Mercury. Any help is greatly appreciated!
sluckey
Re: Mercury Magnetics Transformer Wiring Question
Post by sluckey »
Wire it the same as your ceriatone PT.
newAmpBuilder
sluckey wrote: Sat Apr 01, 2023 1:25 pm Wire it the same as your ceriatone PT.
OK so one lead goes to ground then. Thanks!
