Warwick Tube Path 10.1 Tone Circuit Help
TonewolfAmps
Post by TonewolfAmps »
Does anyone have some insight as to how this tone circuit works on the Warwick Tubepath 10.1?
I'll pay anything to get something for free!
maxkracht
Re: Warwick Tube Path 10.1 Tone Circuit Help
Post by maxkracht »
Just switching different bypass caps in and out, don't let the solid state stuff scare you.
Post by Stevem »
That schematic has big problems on that first gain stage!
Unless that switch in v1A's plate circuit is set for high gain, then no signal gets into the rest of the amp!
thetragichero
Post by thetragichero »
graphic eq using gyrators. if you'd like to adjust the frequency/Q of any of the filters, this would help avoid getting out the pencil and paper: http://www.muzique.com/lab/gyrator.htm
TonewolfAmps
thetragichero wrote: Fri Aug 26, 2022 2:05 pm graphic eq using gyrators. if you'd like to adjust the frequency/Q of any of the filters, this would help avoid getting out the pencil and paper: http://www.muzique.com/lab/gyrator.htm
Good link thanks
TonewolfAmps
Stevem wrote: Fri Aug 26, 2022 10:28 am That schematic has big problems on that first gain stage!
There's actually no switch there on the actual amp, it's a 100k vol (gain) control there.
