I have loose plans for a pedal steel amp, and got inspired by the Dr Z Surgical Steel amp. It uses an EF86, TMB tonestack and 2xKT88 (UL), presumably an LPT PI. That's all I know about the circuit.
Having a small stash of NOS EF86s and experience with the Route 66 and Z28 preamp, I thought that topology might be a good idea (perhaps with KT66s and NFB with a presence control).
Also, the ODS type tonestack is IMO the best there is (of the ones I've built and experimented with), so I immediately thought that would be the one to go for.
The goal here is obviously maximum output (in the 50-100W range) with the least amound of distortion and a well balanced tone from a simple and straightforward circuit. I'm not ready to get into a SSS build, and also don't want a Twin Reverb type amp.
Now, having a stash of tubes is no good reason to choose tube types, so I'm prepared to change my mind on that
So I guess the question is, what is your take on this? How much does the ODS tonestack mess with impedances and drop gain? Grateful for any advice and ideas!
